you need to post here your dump from flash 29f400
WinWoj (11th December, 2017)
no the immo is only on the flash 29f400 post it I will help you
orginal flash from second hand ECU:
Tested solution
pass in your pm
plz dont forget thanks+rep
strawberry91 (6th September, 2021), WinWoj (14th December, 2017)
WinWoj (18th December, 2017)
ok, car started and run away. has such fault causing check engine lamp, but i did't read dtc's yet. is it possible that different codig or something..?
many dtc's, all 'intermittent' but can't erase - not lexia... is it possible to set dtc erase count to zero, reset dtc counter? how to make it, flash again??
I think then software version are different..
may be someone can make your ori file immo off,,, I dont have ori file of that immo off dump,, we could it compare
WinWoj (16th January, 2018)
Mates, car came back already for ori flash issue. Please immo off this file, because :
- second hand ecu HW: 9642606280 SW: 9664937580
- immo off file ecu HW: 9642597680 (few DTC'c)
- orginal below ecu HW: 9644955480 SW: 9663600880
please help me immo off orginal:
For this type ecu only emulator, not need modify flash, all others method it mix software from 1.1 L engine and it way to bad work car.
Wysłane z iPhone za pomocą Tapatalk
Production and development professional IMMOBILIZER/TCU/ESL/ELV/SRS emulators for all brand cars
PORSCHE / FERRARI / MASERATI - immobilizer solutions
VAG IMMO CALCULATOR SOFTWARE
