Results 1 to 14 of 14
Thread: Bmw 520d 136 ps
    Dec 2016
    Default Bmw 520d 136 ps
    Hello, i have an bmw 2.0d 136 ps and at the moment i have an chiptuning on it but i don't know how many PS does it have and Nm. The max speed is 200 km/h. Can anyone read the ecu and tell me if it's good or not and the PS and Nm. Thanks a lot
    Oct 2017
    please post tuning file and original file . that all can look defferance
    Dec 2016
    I bought the car like this. I don't have another file. I had another 520d and that had 220-230 max speed and less fuel. The mileage were the same and that is why i asked if this tuned file is ok . Thanks
    i have an original file from another 520d.
    Dec 2016
    Can anyone increase the torque, power and max speed for the first file? Thanks a lot
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    Your max speed raised.
    Chiptunning / EGR / DPF / FAP / DTC / FLAPS / Adblue / ETC.... CUSTOM SERVICE / FILE SERVICE / 24/7 Support
  6. The Following User Says Thank You to Ignasvw For This Useful Post:
    delu (14th December, 2017)
    Dec 2016
    i tried to write it but it gives an error at 83%, error SK1, error SilentKey. whay shoul i do? thanks
    Nov 2016
    uk
    Write original file back to car and see if car starts
    sdtsedat's Avatar
    Jan 2015
    Belgium
    Does the car start after write ori file? I understand that you write with galetto 1250/1260?
    Best to use is kess or other tool for read write.
    Sedat Garip
    Chiptuning Remapping, file service, stage 1 & 2 dyno tested.
    Diesel + petrol All cars
    Manual Adblue dpf egr Opf tested working solutions
    Belgium
    With Kind Regards,
    Don't forget hit thank button if i helped.
  10. #9
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    my winols didnt recognized file that he read and i modified. Galleto doesnt correct checksum? Because he read it with g4 i guess
  11. #10
    maajkii's Avatar
    Mar 2017
    Poland - Sława ( Lubuskie )
    no chks with gall for this ecu, if you need chks post file i will calculate it
    DSG TUNING
    File Service
  12. #11
    Dec 2016
    I read the file with gal v54, write with gal v54 and gal 1260 and same error. Write original with gal v54 and gal 1260 and car starts. only with the file with max speed corrected have problems. Thanks
  13. #12
    Dec 2016
    first is the original file with chiptuning and the second one with max speed off.
  14. #13
    maajkii's Avatar
    Mar 2017
    chks was wrong.
    here you have with good chks no pass
    DSG TUNING
    File Service
  15. #14
    Dec 2016
    i will try and report. Thanks
