Results 1 to 15 of 19
Thread: 2008 ford kuga
    Nov 2017
    Default 2008 ford kuga
    Hello. I have a problem with ford kuga keyless. No ignition, no start, steering wheel are locked. All fuses ok. No faults in remote keyless module, no faults in GEM module. Car locking and unlocking with remote, battery are good. I try both keys, but no luck. Try disconect battery, no luck... can someone help me please?
    Dunker's Avatar
    Yorkshire
    Had a 13 plate a couple of months ago doing same. ECU shit itself for no reason. 2nd hand ECU fitted then to Ford for programming "as built" because normal incode/outcode wouldn't work.
    V Series TMS470 / EEPROM data - encryption / decryption, totally pwned.
    IEC 62056-21 - new discussion: sonsivri.to/forum/index.php?topic=60412.0
  3. The Following 2 Users Say Thank You to Dunker For This Useful Post:
    Meat-Head (15th May, 2022), volodin69 (17th May, 2022)
    Nov 2017
    I try to feed 12 v to 19 fuse in engine bay to turn on ignition manualy. In engine ecu vas fault p1622 immo id not match, but I erase fault, and no faults come on. This peace of crap still no start.
    Nov 2017
    Problem vas a bad electronic steering lock
  6. The Following 2 Users Say Thank You to darius211 For This Useful Post:
    Dunker (15th December, 2017), volodin69 (17th May, 2022)
    catalinosonesti's Avatar
    Mar 2019
    east nord pole
    I have the same problem with Ford Kuga mk1 2012 , i don t have ignition on dash ( only km see ) .I remove the dash and i power it on tabel and all lights are on.
    The batery are ok ( 12.39 V ) also the both key batery are ok ( 3,30V ).
    The steering is not bloking and work , because i push the car, also the remote from key work both .
    If someone have any idee about this problem , please write , any sugestion is wellkome.
    Best regrads
  8. The Following User Says Thank You to catalinosonesti For This Useful Post:
  9. #6
    Meat-Head's Avatar
    No, nice to see recycling going on in the forum
    have a look in trunk lefthand side, earth point, beyond that no
    focus though
  10. The Following User Says Thank You to Meat-Head For This Useful Post:
    catalinosonesti (15th May, 2022)
  11. #7
    Mar 2019
    east nord pole
    focus though
    There i have confort Module and yes it is 4 or 5 wires ground. Looks ok ,no rust or damage.
  12. The Following User Says Thank You to catalinosonesti For This Useful Post:
  13. #8
    Meat-Head's Avatar
    Ok google the part number but understand that to be the other end to the starter button
  14. The Following User Says Thank You to Meat-Head For This Useful Post:
    catalinosonesti (16th May, 2022)
  15. #9
    Mar 2019
    east nord pole
    Basically, I tried to put a navigation that has the built-in climate and having the power plugs just like on my car. The space behind my Visteon V series radio is not permanently mounted large ships. I gave up the idea and mounted the car's radio and climate, and since then the car has not started, the windows do not work, there is no contact, only the central locking works.
  16. #10
    Meat-Head's Avatar
    Trapped wire or shorted canbus
  17. The Following User Says Thank You to Meat-Head For This Useful Post:
    catalinosonesti (17th May, 2022)
  18. #11
    Mar 2019
    east nord pole
    Thank s , i will chek the canbus and wires .
    I Post the result.
    The plug in are the same in car what i have clima but i think the NX navigation some Pins are diferent .
    That s i think i burned some think.
    It works only central looking,no start buton,no emergency Light,no Light.
    Thanks for your time spend to help me.
  19. #12
    Mar 2019
    east nord pole
    Hi , again ,
    I recive a call to the workshop and they told me the problem is not about wires , conection or CAN comunication . Something in the sterring module not reconize the 0 posiiton of the stering that s why i dont have ignition.
    It s could be posible ?
    They manage to conect with tester on the car and i don't have any error on the Gem module.
    What can do to put in 0 position that module ?
    Best regrads
  20. #13
    Meat-Head's Avatar
    No sounds like corruption of module
  21. #14
    Mar 2019
    east nord pole
    Hi .
    Still no ignition , i change start button, Gem module ( fuse box) in the car , anttena all 3 are ok ( see the key ) , but no ignition .
    I have this error :
    RKE - P1367-60
    RKE - B159A-60
    What can be damage on this car .
    I never ,never , never try to put original Navgation HSRNS on ford kuga mk1.
    My wrong cost me now .
    How can help me with some advice i will apricate.
    Best regads
  22. #15
    Mar 2019
    east nord pole
    I recive an ignition diagram , and i see i have 2 wires on the start button how go to the RKE module how is back in the car , if the wires has continuity then the module have problem .
    From were i must to take data to write again this module , or what i can do to delete this error : P1367-60 and B159A-60
    Best regrads
