You need to put NEW sd card then use token reset
Wysłane z iPhone za pomocą Tapatalk
I've been using for some time now kess v2 4.036 K10033818, until recently i've received notice sayin last nine programmings left, tokens right?.
So i used tokens reset utility provided by the chineese, followed procedure carefully "Kessv2 4.036 SE87-C Add Tokens" (was on the cd) it updated etc, but no change still getting message that within nine programings device has to be updated...... etc ..... everything is greyed out, can't do anything...
my question is is there any way to get it running again or have i bricked my clone somehow....?
DSG TUNING
File Service
completely new, or is just enough to format the old one??? 4gb should be enough? fat32 formatted i persume...?
I use new 8gb class4 microSD card
But 4gb should be enough
DSG TUNING
File Service
kysioo (14th December, 2017)
i've tried with new sd, when i ran this tool it said no valid token file, so i ran just that ksuite from token directory, it updated, and when the screen appeared everything was greyed out, except for the boats - i never had them before. So i went to my normal ksuite i always used, and it gave mi error restart application to complete update.... other version that also worked before gave me the same.... any ideas?
situation update..... i took yet another brand new 8gb sd, used another winxp pc, and ran token utility, this time it worked... thanks for help
DSG TUNING
File Service
DSG TUNING
File Service
