Citroen c3 1.4 hdi sid806 egr off
    Mar 2016
    Default Citroen c3 1.4 hdi sid806 egr off
    Hi All
    I need help with egr off and cks ok for sid806
    Thanks and Regards
    Mar 2016
    Problem solved
    For All
    Pls Press "thanks"
    plug disconnect
  3. The Following 16 Users Say Thank You to marcin7091 For This Useful Post:
    0soinsa (7th September, 2020), abdmrknjc (22nd August, 2023), AleXPaiN (3rd May, 2023), brad123 (3rd November, 2019), credoline (14th December, 2017), gyapi11 (26th January, 2023), isavrseno (26th May, 2022), jkubp (6th October, 2022), koki (6th January, 2022), leonida (13th January, 2021), lfa450 (16th September, 2020), lukasz12345 (5th December, 2023), pedritos (26th January, 2023), Roche (19th August, 2018), sonho1999 (1st April, 2019), Troen (16th November, 2022)
    Jan 2016
    what about immo ?? it is stored in Flash ?? if I write this EGR off file to other ECU ( with same numbers ) it will works or immo will block the car ?
  5. The Following User Says Thank You to mrchip For This Useful Post:
    loreto (15th May, 2019)
  6. #4
    Oct 2018
    nice job frends
    Oct 2018
    why cant downolad ?
  8. #6
    Sep 2013
    Thanks to the help of user marcin7091 , I managed to do egr off to a sid806 but with different software. I took a cue from your edit. place the files
    modification with disconnected connector
