Hello to All
I need Help to put zero into this bsi delphi with 95128
i attached file bsi , original value km 10871
Hello to All
Dr. Zoidberg (14th December, 2017)
hivrich (14th December, 2017)
Good morning and thank you for your help
sorry for my english, I use the translator
sorry Hivrich, but I have not used your file,
I was not convinced the area on line 2940, because there was a bad cks ,
try to try I preferred one of my solution that was successful,
clearly I want to share with you , I also attached the bsi connections to read the 95128 without
detaching the 2 cards (from smok) original value 10871 changed value 800
dash marelli tft 95160 from 10871 to 800
bsi delphi 95128 from 10871 to 0
regard to all
Abdo Abdelatif (23rd January, 2018), arti1 (3rd January, 2024), biya (12th January, 2020), capi (24th May, 2019), eeprom241 (11th March, 2022), esse (16th January, 2018), gijsvm (6th November, 2019), Hayssam1 (26th September, 2020), hivrich (15th December, 2017), khaleddaddi (24th October, 2023), mariomarcelo (24th April, 2021), Pavel-DN (4th July, 2023), scotlock (30th November, 2023), SergeyIg (14th May, 2018), Spike999 (19th January, 2018), volorucinski (12th March, 2020), wadim21 (6th November, 2019)
strange but true, I knew of that second cks, but I did not know how to calculate, in fact mine was an attempt .... went well
I have covered a 2 km and the speedometer works well
IMG_3862.JPGHi, tried your pin out this morning but could not get coms. How did you separate the PCB's?
Many thanks Vaughan
adjee (24th February, 2019)
Hello
i attached file bsi , original value km 47400
THANKS FOR THE INFORMACION , I WILL TRY YOUR PINOUT .
