Results 1 to 15 of 15
    tony59's Avatar
    Sep 2010
    Default Citroen C4 Picasso Model 2017 Bsi Delphi
    Hello to All
    I need Help to put zero into this bsi delphi with 95128
    i attached file bsi , original value km 10871
    Dr. Zoidberg's Avatar
    Oct 2015
    Talca-Chile.
    Quote Originally Posted by tony59 View Post
    Hello to All
    Are you sure of your reading?....
    hivrich's Avatar
    Sep 2012
    Ukraine
    Quote Originally Posted by Dr. Zoidberg View Post
    try this....
    Attachment 492792
    Maybe it will be better
  4. The Following User Says Thank You to hivrich For This Useful Post:
    Dr. Zoidberg (14th December, 2017)
    Oct 2015
    Talca-Chile.
    Quote Originally Posted by hivrich View Post
    jejejej , I went the hard way .....
  6. The Following User Says Thank You to Dr. Zoidberg For This Useful Post:
    hivrich (14th December, 2017)
    tony59's Avatar
    Sep 2010
    Good morning and thank you for your help
    sorry for my english, I use the translator
    sorry Hivrich, but I have not used your file,
    I was not convinced the area on line 2940, because there was a bad cks ,
    try to try I preferred one of my solution that was successful,
    clearly I want to share with you , I also attached the bsi connections to read the 95128 without
    detaching the 2 cards (from smok) original value 10871 changed value 800
    dash marelli tft 95160 from 10871 to 800
    bsi delphi 95128 from 10871 to 0
    regard to all
  8. The Following 17 Users Say Thank You to tony59 For This Useful Post:
    Abdo Abdelatif (23rd January, 2018), arti1 (3rd January, 2024), biya (12th January, 2020), capi (24th May, 2019), eeprom241 (11th March, 2022), esse (16th January, 2018), gijsvm (6th November, 2019), Hayssam1 (26th September, 2020), hivrich (15th December, 2017), khaleddaddi (24th October, 2023), mariomarcelo (24th April, 2021), Pavel-DN (4th July, 2023), scotlock (30th November, 2023), SergeyIg (14th May, 2018), Spike999 (19th January, 2018), volorucinski (12th March, 2020), wadim21 (6th November, 2019)
  9. #6
    drpeter's Avatar
    The Netherlands
    regard to all
    So this is working? Strange, the cs in the bsi is wrong, at 0km the cs is 6BE9, not 0000!
  10. The Following 4 Users Say Thank You to drpeter For This Useful Post:
    DashProg (15th December, 2017), Johnner (15th December, 2017), Safety (6th February, 2019), SergeyIg (15th May, 2018)
  11. #7
    tony59's Avatar
    Sep 2010
    strange but true, I knew of that second cks, but I did not know how to calculate, in fact mine was an attempt .... went well
    I have covered a 2 km and the speedometer works well
  12. #8
    drpeter's Avatar
    The Netherlands
    ok my scripts calculate the cs but i think it is not needed then, thanks. I never had this car so could not test it.
  13. #9
    Quote Originally Posted by drpeter View Post
    i think because the cs is not correct it auto make mileage 0km and it take the dash mileage!
  14. #10
    Nov 2013
    South East England
    IMG_3862.JPGHi, tried your pin out this morning but could not get coms. How did you separate the PCB's?
    Many thanks Vaughan
  15. The Following 3 Users Say Thank You to Spike999 For This Useful Post:
    adjee (13th February, 2019), capi (24th May, 2019), Hayssam1 (28th September, 2020)
  16. #11
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Hello to All
    Did you have to split the board to get access to the eeprom?
  17. #12
    Jul 2015
    My Car
    Quote Originally Posted by Spike999 View Post
    Many thanks Vaughan
    hi friend
    can you help me with pinout of delphi bsi
  18. #13
    Cllau's Avatar
    Mar 2017
    where friends need me
  19. The Following User Says Thank You to Cllau For This Useful Post:
    adjee (24th February, 2019)
  20. #14
    Feb 2009
    Croatia, Zagreb
    Hello
    i attached file bsi , original value km 47400
  21. #15
    May 2019
    THANKS FOR THE INFORMACION , I WILL TRY YOUR PINOUT .
