Why do you need more cables?
Hi mate,
I need help on how to read this module correctly upa-s
I found pinout with only 4 cables...
Link: https://4.bp.blogspot.com/-Q62r8qlh8...icked-FRM3.jpg
but I do not try to read and I only get "00"....
you have to use more cables, you need another pinout?...
Thanks in advance...
Bmw frm -e mask 3M25J 9s12xEG384
WINNER THE LOSER
Well, it does not give me a reading ... with those 4 cables..
some trick to read it correctly?
WINNER THE LOSER
What are you reading EEPROM, DFlash OR PFlash?
Probably EEPROM corrupted.
WBR, Marek
The conection then read "00"...
I try to read D-flash and P-flash tried to repair
WINNER THE LOSER
That connection is correct. I had some trouble reading FRM with upa-s also can't remer what. But with xprog box works perfect.
SEE these vídeos.
https://www.youtube.com/watch?v=qw0saCTakMI -- XProg
https://www.youtube.com/watch?v=kOKB14EA6Js&t=11s -- UPA
If i help, d'not forget to press thank button!!
automotrizVIP (16th December, 2017), crisvenua2 (25th November, 2020), speedservice (12th May, 2020)
Ok mate .... Now I understand how it works...
someone has a true complete from repair
D-flash, eeprom, p-flash... to all...
Thank you.
WINNER THE LOSER
IS IT NORMAL TO BE DAMAGED AFTER THE BATTERY IS CHANGED?
The customer says that after this happened, there were many faults in the car....
then on other occasions I used the Scanner Autel XXX to solve this and it worked for me but now in this car this solution has not worked ...
can someone help me with a good file for this car?
WINNER THE LOSER
has already been solved
reading with upa-s was a success. and equal programming.
although I would like to have the software that a colleague used here.
WINNER THE LOSER
This website can do it!
http://tlvps.tomvanleeuwen.nl/frm/
if I read it for there in the forum.
which my colleague uses shows you
vin oem; -------- km:-------- numer keys;---- numer part: ------ otros-----
WINNER THE LOSER
