Results 1 to 4 of 4
    Oct 2012
    Default Lupo 3L manual conversion
    Hi Guys,
    I´m doing a conversion to manual shifting in my Lupo 3L.
    I need help in changing the ecu software to make the car run without transmission ecu.
    I read about modifying a 1.4tdi software , but i`m unsure if just copying maps
    e.g. SOI /Duration would be enough to make it run.
    I hope someone with more experience can help me out.
    Below the original file is attached.
    Thanks in advance
    Nov 2009
    Above sea-level
    try this one
    Nov 2015
    Lublin/poland
    software 1.4tdi noot good engine works check pm
    Top Poster janeca's Avatar
    Jun 2010
    Have the same problem.. 1.4 ecu runs fine but have some problems wen the engine is cold, first time run the engine never runs... always at the second time. Any Help?
