you write it over obd? and if yes , why?
Yesterday i write GOLF 6 2.0 TDI 170HP 2011 with ecu EDC17CP14
0281015988 - 1037507614 - 03L906022LC
Writing with Kess 5.017 Red Board blocked at 70% at car dont' start
Function Recovery with KESS also blocked at 70%
I post read file with K-TAG 7.020 after blocked
SOMEONE COULD HELP ME TO UNDERSTAND THE PROBLEM, THANK IN ADVANCE!!!
KTAG READ.rar
i always write EDC17CP14 in OBD and never problem
I was wrong, but I still have to solve the problem
Here is test file
let me know result
IF YOU THINK IT'S EXPENCIVE TO HIRE A PROFESSIONAL,WAIT UNTIL YOU HIRE AN AMATEUR
please resent me password, i clear inbox
TPROT_V07.00.00/1796 ... 100% protected
(\__/)
(='.'=) This is Bunny. Copy and paste bunny into your
(")_(") signature to help him gain world domination.
l have always worked off this list ?
-03L906022NH 3397 1037399332 tc1796 NO TP
-03L906022NH 4388 1037500120 tc1796 NO TP
-03L906022NH 5509 1037506174 tc1796 NO TP ,
no tp 1037563984 no tp .
1037563980 no tp
and normally write fails at 99%
if cars had an update might be a problem ?
this info from magpro
I problem: ECU VAG EDC17CP04/14 blocked writing MOD by OBD (so called EEPROM crash)
caused by: ECU remain in programming mode.
1. Read IROM / XROM and EEPROM in bootloader mode.
2. Fix IROM/XROM using bootloader readout and OBD ORI readout (you will probably need to paste part of map zone and chk/RSA zone)
3. Write fixed IROM/XROM by bootloader (do not touch EEPROM!)
4. connect ECU to the car and write repaired IROM/XROM (same used for bootloader) by OBD.
It will automaticaly fix eeprom problem.
Resolved
II problem: ECU VAG EDC17 blocked writing IROM /XROM by bootloader. Cannot read anymore IROM/EEPROM
Caused by: damaged sector 0 by interrupted writing
1. find someone with MAGpro2 X17 or T-BOOT tool
2. Write IROM / XROM by X17/T-BOOT using OPTIONS= ALL
resolved
MAGICMOTORSPORT Team
magicmotorsport
0soinsa (17th December, 2017), chli1976 (18th December, 2017), Col19 (3rd September, 2021), daniel guerra (17th December, 2017), drewdom (25th July, 2019), Stelaras26 (25th February, 2020), teerak2uk (17th December, 2017)
0soinsa (17th December, 2017), Col19 (3rd September, 2021), norman1967 (18th December, 2017)
should be able to send read to alientech or mms and they can tell you straight away if its tp file
anyone could repair my EEPROM and make chechksum?
I found this ori read with ktag (flash only)
it has some difference only in checksum area so I think your problem is in eeprom. follow those instructions from MMS
with his eeprom he does not go into the diagnosis and does not ID in OBD
