0soinsa (18th December, 2017)
writing ori be obd or use flasher to flashing this ecu frf orginal file and car start. When start use k-tag to read in boot mode or Kess vread and writng by obd.
FILE SERVICE
I repeat in OBD not make ID with KESS and non function DIAGNOTIC!!!!! OBD NOT WORK!!!! EEPROM IS DAMAGED!!! SOLUTION IS REPAIR EEPROM!!!
NO PASSWORDS FOR ANYONE, EXCEPT THE RECIPIENT OF THE FILE !!!
If your PM box is full, clean it right now...
Otherwise, your requested file will be deleted... for ever!
0soinsa (18th December, 2017), drewdom (25th July, 2019), mvekaz (11th October, 2019), pulsar2000 (26th July, 2019)
You are right! I had written from the beginning of the problem is in eeprom, but all insist on writing obd and write obd ...
why do you think you can't flash FRF with appropriate tool if eeprom is damaged?
0soinsa (19th December, 2017)
problem solved! one user repair eeprom and flash and car start! thank you all at partecipation!
kidloco (31st January, 2018)
have same problem,who can help me,
teerak2uk (25th September, 2018)
Hi Guys!
I need your help - i tried to remap my girlfriends Audi A5 2.0tdi (143hp) (2009)....
I'm owning PCM Flash + EDC17.x module and a Kess eu version.
I wanted to read/write the car via obd - took pcm flash -> ecu id -> grabbed the correct virtual read file -> and tried before any remaps flash the stock file via obd...
Unfortunately the write process stopped during (write block1 - that was erased before) so i fear that was tprot that caused that...
Then i took out the ecu and tried it via kess bootloader - ecu id not possible, write process not possible, only a backup read for eeprom and micro was possible (saved together in one file)
What can i do? Is the ecu bricked?
Thx & BR
Chris
Hello gfck1,
You can write in PCM suport forum . For module 65 "VAG MED17/EDC17 CAN TP2.0/K-Line":
http://pcmflash.ru/forum/viewtopic.php?f=16&t=1098
for module 48, 50 - VAG MED17/EDC17 UDS:
http://pcmflash.ru/forum/viewtopic.php?f=16&t=212
Try write in english, if no answer- use google translator.
I think You will get help. You can recower that car with pcm flash.
Best regards,
Jordan
