Results 1 to 11 of 11
    Default urgent help please kia forte 1m250
    please i need help with dump forte 95910-1m250 eeprom 95256 dump attached ver 1.2
    narkeleptk's Avatar
    May 2017
    USA
    Quote Originally Posted by gselectric View Post
    Let me know how it goes. Thanks.
    is it tested because car is far away thx
    narkeleptk's Avatar
    May 2017
    USA
    Looks pretty much same as a 1m100 forte I just did that went ok, just wait for others then. I don't want blame if doesn't work out for you.
  5. The Following User Says Thank You to narkeleptk For This Useful Post:
    gselectric (16th December, 2017)
    hiiii sir no dtc but light still on
    dragon100's Avatar
    Jan 2012
    From land of milk and honey
    Check pretensioners, sometimes light on but no errors when pretensioners bad ...join resistors 2,2ohm and clear errors ...
    Best regards.
    Dragon
  8. The Following User Says Thank You to dragon100 For This Useful Post:
    narkeleptk (17th December, 2017)
  9. #7
    narkeleptk's Avatar
    May 2017
    USA
    I dont have the clear anymore to post, so feel free to share it again. Maybe Dragon can check it better for you, he is much more experienced in clearing.
    There was 01 on line i think 3240 x03 that might need to be 00. It was slightly different in the file i was comparing with so I left it alone thinking it was just some of the part#.
  10. The Following User Says Thank You to narkeleptk For This Useful Post:
    gselectric (17th December, 2017)
  11. #8
    dragon100's Avatar
    Jan 2012
    Check this, pass in pm.
    Best regards.
    Dragon
  12. The Following User Says Thank You to dragon100 For This Useful Post:
  13. #9
    thx both r same dumps i will try pretensioners
  14. #10
    ttzag's Avatar
    digital-kaos
    here is 100% working dump
    Actions speak louder than words
  15. #11
    hello today car passed by when i put original crash dump i can connect scannere ,but i tried all posted dumps scanner cannot get into airbaG AND LIGHT STILL ON ANY HELP PLEASE?
