Have you tried vcds?
did any one had the chance to program the new remote key for Octavia a7 2014
i want to program just the remote part not the key
if its possible what tool do i need
thank you all
you cannot program remote key for MQB with VCDS , no separate procedure .
when you program the transponder , the remote will work automaticly !
you have two choices in the morning: go back to bed and continue dreaming, or you get up to make your dreams come true
haroutioun (17th December, 2017), just4upal (17th December, 2017), teerak2uk (17th December, 2017), yugo45 (18th December, 2017)
will this is not completely right.
there is a body computer under the steering wheel its some how responsible for the central locking, some times its goes bad we just change it with new one or used.
if we need the remote to work we had to go to dealer and thy adapt the original remote to car not the transponder, the remote that was working with the bad unit.
if we dont need the remote "central locking" to work no adaption needed.
we had done this several times this unit is faulty.
i want to know is there is a way to do the adaption without dealer i dont want transponder now, because i can see i kedy thy had a remote for the 5th generation for vag
Yes I think it is also based on 09 central electric module for remote coding ?? Correct me if I'm wrong.
yes , you are convinced , otherwise you don't write this , once again , no waste your time no separate procedure !
