find mdi or mdi2
Only then can you handle the car.
still global, gds
Opel Insignia 2010 year. A20DTH engine.According to the owner's story, the mechanic repaired the engine
and had to remove the clamp.Since then, the engine will no longer be running.After more than a month of trying to start the engine, he gave up.The car is now in my workshop.
The first thing I noticed is that the BCM and Engine ECU were opened.
I read the errors an noticed
ENGINE ECU
P0563-System voltage, high voltage, permanent
IPS Instrument
B3902-Wrong immobiliser identifier received
U0020-Low speed Communication bus
ECC Climate control module
BCM Body control module
B389A-Environment identification
I found the login code in BCM ( 24c16 ) and programmed the key.
The engine will not start and the same errors reappear.That's all I could do with OP-COM.
I can not do the configuration of the module, and read live data from the immobilizer.
Is it possible to make a configuration or reset of the module with the VCX NANO for Opel GM.
If someone knows how to solve this, ask for help.
find mdi or mdi2
still global, gds
A topic that interests me
Login in BCM is 1381. Can someone calculate login in IPC. I want to check if they agree
