Results 1 to 10 of 10
    Default Toyota Camry 2007y - all key lost
    Hi, I need any information about programming key to Toyota Camry 2007y usa. Old key was damage but inside was glass-tansponder. Is it 4D ID60? I must read eeprom from immo or ecu or is other solution? I have X100 and other programmer. I must buy master and slave key or blank transponder? I never made keys in Toyota... Thanks for any help!
    Read eeprom from immo and post here/
    X100 has options Reset immo and Reset ECU, is useless in this case?
    narkeleptk's Avatar
    May 2017
    USA
    that year camry is 4d67. What you saw was prob a TPX2 chip copy of a 4d 67.
    use your tool and reset immo. Insert new 4d67 for a minute then remove it, then insert and ignition on/off 6 times quickly.
    At first need to know what type of transponder inside. What generation that Camry 30 or 40? If 40 - narkeleptk wrote right.
    narkeleptk's Avatar
    May 2017
    USA
    USA camry is only 4d67 or no chip that year.
    use 4D 67 : 72 (master key) if you making your own chip. or if buying aftermarket key just buy any version of TOY44D
    thanks for the answer. You can be right because the key is not original (SILCA copy). Must be new 4d67 or can be from other Toyota key? Thats true, I need two keys? X100 show information that I need MASTER and valet keys
    Sorry but I didn't understand how works MASTER or valet transponder. I can buy new blank id67 and precode it by vvdi2 or zedbull?
    It is Toyota Camry 2007-2011y
    Camry as your photo have 4D ID67 inside. You can precode simply blank id60 to id67. Or transponder can be from other Toyota id67 used. Used key work ok, tested
  9. The Following User Says Thank You to Zet-kv For This Useful Post:
    tomlib (19th December, 2017)
  10. #9
    narkeleptk's Avatar
    May 2017
    USA
    You can program just one key, that is ok. It will program as a master. The way I described in previous post.
    Or if you want add more keys, you can do this process. Buy 3 Toy44D key blanks.
    After Reset with your tool, remove key.
    >insert key1 (do not turn)
    wait 1 min.
    >insert key2 (do not turn)
    wait 1 min.
    >insert key3 (do not turn)
    wait 1 min.
    Now you are done.
    Key 1 & 2 will be master keys, key 3 with be valet key.
    Master keys can be used to program or delete other keys, valet key can not. That is really only difference in this case as far as the chip data goes.\.
    USA Toyotas are much easier then oversea models.
  11. The Following User Says Thank You to narkeleptk For This Useful Post:
  12. #10
    Thanks friends for help! Reset immo by X100 and two new ID67 solved problem
  13. The Following User Says Thank You to tomlib For This Useful Post:
    narkeleptk (19th December, 2017)
