Results 1 to 13 of 13
    Mar 2012
    Default Peugeot 307 2.0 100kw DPF Off
    Hy guys. i need dpf and adblue off to peugeot 307 2005 2.0 100kw RHR. thank you
    johak's Avatar
    hi write this and report
    Mar 2012
    i must to remove adblue module?
    Mar 2012
    it say diesel additive at minimum level
    johak's Avatar
    disconnect module and diff pressure sensor
    Mar 2012
    i did not find module. but i will fill additive tank
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    Additive module could be under rear passenger seat. On 407 additive module is under dash. On 307 maybe there is no additive module
    Chiptunning / EGR / DPF / FAP / DTC / FLAPS / Adblue / ETC.... CUSTOM SERVICE / FILE SERVICE / 24/7 Support
    johak's Avatar
    write the file disconnect diff. pressure sensor and see if there is a problem
    for now do not fill the tank
    Mar 2012
    it still say there is low additive
    johak's Avatar
    do you have obd code for this error?
    johak's Avatar
    wait................
    Mar 2012
    i will check later. in obd nothing say. just in dashboard screen
  13. #13
    Jul 2017
    You must be in diagbox or PP2000 add fap replacement and fill or replace the diesel additive.
