Hallo,I have seat inca 1,9 sdi 1996 ,and need PIN or IMMO off
ECU is
BOSH 0 281 001 407/408
028 906 021 CQ
i sending twoo eeprom dump B58323 left and right ( right is eeprom near eprom and xtal )
THANX and Marry Xmas !
ECU is
028 906 021 CQ
Try use this.
Remove immo box.
Please could you re-upload the rar file - it seems that the one you had uploaded is someway corrupted (I cannot extract it with any zip/7zip extractor). Thank you very much. Fedas.
Just download latest winrar and unpack
Dont work,only crank 1 sec.
Thnx
Reality of life :
1:Never argue with an idiot, he will pull you down to his level and overcome you with experience
2:Envy is the confession of inferiority
3:Everyone lies
How much trash you leave behind so much trash someone will have to read or maybe you yourself
If you like reading garbage, don't slow down, just speed it up
Thnx
Wich immo box you have on car?
Do you have immo box?
If you have read motorola hc05 from immo.
fedas (24th December, 2017)
Reality of life :
3:Everyone lies
orig. immo box is damaged did not read HC05, i have second immo and immo PIN but missing me PIN ecu ,so I can not pair with VAG.
Eeprom programming is ok, two times verified with carprog.
Is there an chip B57678 should it be EEPROM 2402, but I still read ff?
Reality of life :
3:Everyone lies
I changed the immo box and learning the key, but the car did not start, the start was done after reprogramming the eeprom from you. Immo box is immo1
skoda Felicia may by dont work with seat?
thnx
