Carprog modification ???
Results 1 to 2 of 2
    otojm's Avatar
    Feb 2012
    Kepler 22b
    Default Carprog modification ???
    hi, bro i have a confusion with the modification in carprog adapter A1 for using with opel or fiat DASH;
    they claim to remove R102 resistor for doing correctly those cars !
    the question is :when not doing fiat or opel cars,we need replace this resistor on A1 adapter or must let it without R102 ???
    Feb 2016
    Russian Federation
    Hi, try it. Often there is a malfunction in the MCP2515. Check the connecting cable between the "main" and "a1" cards.
    Hi, try it. Often there is a malfunction in the MCP2515. Check the connecting cable bcarprog-a1-adapter-good-1.jpgetween the "main" and "a1" cards.A1 Carprog mod.jpg
  3. The Following User Says Thank You to cokejay For This Useful Post:
    crisvermex (19th February, 2018)
