No needle on this...
Yea 2 model of cluster that I know of for these so far...all digital except for temp and fuel gauge needles on this one.
temp needle come out at top part...fuel on the other hand comes out with the middle pin and when u set it back..the fuel gauge have to set all the way at the top which is full. unlike the temp needle where you set at the bottom cold.
🔥Wacka Wacka 🔥
Berubeg (4th March, 2018)
someone have pinout to read from the back side....hard to disasembly
best regards
finally open...
please i need 6000 km
93c86
original km:13078km
crv 2017
thank's
here is your file
Berubeg (19th March, 2018)
Someone see 12685 km somewhere in my dump for mileage since last battery disconnected? Possible this data in this eprom?
You can provide a picture of how it appears to you, so we will get a logic out of your problem ...
WINNER THE LOSER
I see this data when i scan the AT module with my ms906 same as view in picture.
Logic then dictates that the mileage for that is stored in the TCM. Have you tried a battery disconnect to see if it changes?
Better to pull the fuses for the TCM though, that way you won't have to get the radio code.
I try battery reset with 906 and with x300 and not supported for this model. Cluster i try tomorrow to remove the tcm fuse because i’m unplug battery 3 times 5 minutes and always there. And when unplug the immo need around 8 hrs to restart the car.
