You can activate from eeprom 24c32/c64
hi friends i have a vw golf 6 i need to activate SCAN NEEDS when i do it with vag com to activate it does not work i read that some dashboard are not compatible for that
17 Instrument
- Adaptation
- staging
activate
[17 - Instruments]
[Coding - 07]
[Long Coding Helper]
Click on each of the Byte numbers in step 3) and you'll see the selectable options below.
Check the box for "Gauge Test/Needle Sweep active"
[Do It!]
all this does not work is what is another way to make this table compatible
thanks in advance
i need staging golf 6
Knowledge creates mysteries.
You need to be quicker
* MK100;
