Results 1 to 15 of 17
    Default Kia Sorento 2017 95910 C5710 infenion XC2361A-72F crash data clear
    hi friends
    i need your help to clear crash data for Kia Sorento 95910 C5710 infenion XC2361A-72F
    thanks in advanced
    hexguru's Avatar
    Nov 2016
    Here you go, pass pm
  3. The Following 3 Users Say Thank You to hexguru For This Useful Post:
    kolocar (7th January, 2018), naelraddad (7th January, 2018), tx-mafia (29th July, 2020)
    Quote Originally Posted by hexguru View Post
    thanks friend your file 100 % ok
    ALEX65's Avatar
    Aug 2016
    HELLOMY FRIEND PLEASE CLEAR THIS FILE
    95910-C5710
    XC6321A
    USA
    What kind of calculator are you using to clear this, which service provider is this, hexguru??
    hexguru's Avatar
    Nov 2016
    Quote Originally Posted by ctype02 View Post
    it's my own calcs for more details see home page
    Quote Originally Posted by ALEX65 View Post
    95910-C5710
    XC6321A
    Crash found!!!
    9 Erros block(s) found
    They contain next errors:
    B1650 Crash recorded in 1st stage only(Frontal - Replace ECU)
    B1102 Battery voltage low
    B1334 FIS-Passenger communication error
    B1329 FIS-Driver communication error
    B1527 Passenger Airbag on-off switch open or short to Battery
    B2500 Warning lamp failure
    and clear file pass pm
  8. The Following User Says Thank You to hexguru For This Useful Post:
    ALEX65 (13th March, 2018)
  9. #7
    ALEX65's Avatar
    Aug 2016
    Crash found!!!
    Thanks my friend
    You best
    فرستاده شده از SM-N950Fِ من با Tapatalk
  10. #8
    israel
    hi for all
    95910-C5710
    XC6321A
  11. #9
    hexguru's Avatar
    Nov 2016
    here you go pass pm
  12. #10
    israel
    hi
    thanks for help but error apeer
    B1620:00-89 - Internal fault-Replace SRSCM
  13. #11
    israel
    hi
    can any one help me to clear crash for this
    95910-D3300
    THAKS FOR ALL
  14. #12
    hexguru's Avatar
    Nov 2016
    Quote Originally Posted by mahmod_q View Post
    hi
    solution tested more than one thousand times, check ACU hardware or dump from another module
    usually 1620 from bad reading or short circuit between layers of the board
  15. #13
    israel
    HI
    THANKS FOR HELP
    ITS OK
    THE ECU HARDWARE ERROR AND I FIX IT
    100% OK
  16. #14
    israel
    HI
    NO ONE CAN CLEAR THIS
    hi
    95910-D3300
    THAKS FOR ALL
    israel
    no one can help
