I have had this on more than a few times. Is immo on?. Have you checked fuses in car, the small 5amp. If so, connect a charger, turn on ign, go away and do something else for an hour or so. I dont know how it works, but has worked for me
Do you get the door chime when you open door, with key in ign? i fully understand what your on about, but try it and see. good luck.
You should first put diagnostic scanner so we can see the fault codes
fault code is p1602 immobiliser engine control unit comunication
anyone have a file please. thanks
original file from car attached. can anyone help please
original eeprom read attached. thanks
can anyone help with a good file.thanks
Nobody can help with good file.please
Sorted it with a file from Ecu company. Strange thing was when I loaded the file,the car started straight away,did not need to program keys. In live data one key is programmed. I need to program other key.does anyone no how to do this. I try through instrument and pats programming,but does not work.
Meat-Head (5th February, 2018)
here is the orginal file.
you only need converter
you always need two keys to program ford vehicels and only works with vcm1
radiosolutions (15th January, 2018)
I was using focom to program m8. But failed
and immo of helps?
Just borrow a key and use that with ring around key barrel - remove it 1st obviously. Use yr 1st key to turn ign on/off when requested.
Focom is a pain in the arse when coding keys but it does work. Half the time u have to program 1 key then do 2nd key after exiting the key programming bit. Obviously 2nd incode needed.
V Series TMS470 / EEPROM data - encryption / decryption, totally pwned.
IEC 62056-21 - new discussion: sonsivri.to/forum/index.php?topic=60412.0
Meat-Head (5th February, 2018), radiosolutions (25th January, 2018)
