delete and add not only add man
eurodash (10th January, 2018)
I tried delete and add same result thanks for reply
Some clusters don't allow learning by PIN, so you need to manually add the transponder ID in the immoblock.
Some clusters need ID48+TP23+CS, so you need to read CS bytes and write them to transponder with correct tools.
Which caddy is this some caddys will only take type 2 remote keys from what i have experienced
u read all 7 bit with zedfull? in the end not should be 00
what 7 bytes did you get?
Pin 43489
cs c0640DF80C800
KevinXTR (10th January, 2018)
c0640DF80C800
c0-64-0D-F8-0C-80-0
c0-64-0D-F8-0C8-00
Something is missing or hidden.
Sure you read dash and not ECU?
eurodash (11th January, 2018)
When you have locked dealer key you must login and wait 5-15 min but sometimes even this doesnt work and have to add key to dump as H2Deetoo said.
Wysłane z mojego SM-G950F przy użyciu Tapatalka
Problem is you did not get 7th byte, you need to do that from working key. You precoded key with only 6 bytes which zed full probably pulled from ECU...that is why you can't learn that key...do you have one working key?
Yes 1 working ky zed full read from car then put working key in antenna read key then put tp23 in antenna to precede message
successful then go to delete and add keys
sorry I gorgot to check back here, the last byte is 00 meaning you have to get it from somewhere else before you pre code it
Yes I did from working key
I know this is video of a Passat b6 but the principle is the same ,
https://www.youtube.com/watch?v=YWMB99rqs1s
eurodash (23rd January, 2018)
