Results 1 to 8 of 8
    Default FRM3 Dflash to EEprom file calculation help needed
    Hello.
    I have dead FRM3 in 2011 BMW E92
    Can somebody calculate for me the EEprom file from My Dflash read ?
    Thank You !
    lechus111's Avatar
    Jan 2014
    Try this.
    I have uploaded the EEPROM but the software # 9308367 appears to be different from what should be in the ECU 9240529. If I'm pulling the EEPROM file from the Dflash read then the software # should match perfectly?
    the Communication with the ECU is restored and I can see it now with Inpa. Central Locking and windows started working but the headlights stay on all the time and no blinkers.
    alektkac's Avatar
    Mar 2016
    Украина
    Try it
  5. The Following User Says Thank You to alektkac For This Useful Post:
    astrofil (11th January, 2018)
    Thank You Alektac.
    Wht software did You use t convert it ?
    Europe
    That would be my dflash_to_eeprom tool (Astrofil used the online version, Alektkac the offline version - hence the files are identical).
    You can use it here:
    http://tlvps.tomvanleeuwen.nl/frm/
    If you click "offline version" you can download a Windows build. If you have Python installed you can just run the Pyton code directly.
  8. The Following 4 Users Say Thank You to tomvleeuwen For This Useful Post:
    barho67 (16th March, 2019), robert1232 (15th April, 2019), stabiel (7th March, 2018), topclef (13th March, 2018)
  9. #7
    Nov 2018
    Brussels
    Is this software for FRM3 only ?
    If I Help You Please Rep + Thanks ME
  10. The Following User Says Thank You to Bryanlocksmith For This Useful Post:
    oxqar (25th October, 2023)
  11. #8
    Oct 2023
    Thanks I need it
