Not working . I have same file made by abrites and after write to ecu I have checksum error in ecu . and immo is still working.
Your file off 100%
dalisman (12th January, 2018)
Hello
I find what is wrong, , basicaly my customer say what his did.
Flash is from different car then eeprom thats why probably was not working your solution.
I have here some med 9.1 read out from eep and flash (from one ecu).
Can you remove from this one ?
Dear All
Thank you for your help. I find what was problem my bdm read eeprom as a 95320 and inside is 95160 so first bdm write half and overwrite with second half which was already Original file.
For All thanks !!!
pin89 (23rd January, 2018)
dalisman,
I suppose you have solved without desoldering and writing apart the 95160 eeprom.
I cheated the bdm by copying the corrected 0x40-7F section to 0x840-87F in order to write it during the spurious second writing cycle.
btw, your observation has saved me a lot of time!
Thanks!
treba immo off med9.1 tnx
GrahamR (21st June, 2022)
Please can you do do eeprom off solution ,dump from 95160 attached,thanks regards
Do what you can with what you have .
ecufix (23rd December, 2019)
