Results 1 to 3 of 3
    Jun 2016
    EU
    Default Need help Scenic 3 2013 ,after bed read by Renault ImmoTool ,
    Hi I have problem some time ago come to costumer for programming new Card ,I may mistake and setup wrong command on the list ,Scenic 2 and try read ,after I use correct software and add the key ,but now I have fault I ECU and BCM I can't delete this fault also costumer go to Renault dealer he say been changed BCM ,so what the best option to fix the problem ,?
    Read BCM And ECU and try fix dump ?
    Or make virgin BCM and add with CLIP ,but not sure I can with my China clone , any over Idea for fix that ,thanks for any sign and help
    Wysłane z mojego HTC One_M8 przy użyciu Tapatalka
    Jul 2013
    yorkshire
    You can with clip. read config in air bag, engine ecu and bsi. All should read same. All on same screen.
  3. The Following User Says Thank You to autoden For This Useful Post:
    darox2005 (13th January, 2018)
    Jun 2016
    EU
    Quote Originally Posted by autoden View Post
    Well ,I can use Renault Pin extractor for calculating outcode ???,I make some older cars but not yet with new platform 2009 up ,
