Results 1 to 4 of 4
Hybrid View
    Jun 2013
    Poland
    Default Scenic III problem after code new card
    Another man coded new card to scenic III 1.6 dci but now start stop system deactivate and brake support. In ecu is error - multiplex informations - informations clutch pedal position. In parking break module is ok , working 20% -80%. I try adaptation uch , break module and no effects. In abs also error multiplex informations error.
    Anyone any solutions?
    Thx
    Wysłane z mojego SM-G390F przy użyciu Tapatalka
    Dunker's Avatar
    Yorkshire
    Doing a full scan on Renaults does bring up CAN errors on certain modules. Do a full scan by all means to get a feel for whats wrong but clear all errors after and read modules one at a time. Look at live data for clutch signal to see if it is actually ok first. Can't see how programming a key can screw things up but you never know...
    V Series TMS470 / EEPROM data - encryption / decryption, totally pwned.
    IEC 62056-21 - new discussion: sonsivri.to/forum/index.php?topic=60412.0
    Jun 2013
    Poland
    I scanned clip and 2 errors is current ecu - information multiplex and abs- information multiplex. Clutch data stream is only in parking breaks module and is ok.
    I don't now how coded card.
    Jun 2013
    Poland
    it was supposedly immediately after coding
    it looks like the UCH did not show information about the position of the clutch pedal from the parking brake module
