hi, thanks you for your post, if I bought a Ktag clone which is already in version 7.020 , what can i do with your solution and firmware , what is it for, i don't understand the problem for the ktag?Is it to rework it?
hi guys, i have k-tag clone sw2.13 hw6.070 that im busy with repairs, blocked due to internet connection, just found sd card 6.070 updates files then saw this thread... i am willing to try this new update but have not done this repair before. also what benefits do you get out of this new firmware update (7.020)?
Someone knows why im not able to download?
I don’t think you’ll be able to flash your nxp it’s locked and needs to be replaced, there’s a solution here in forum that it’s with heat that way you’ll be able to unlock the chip but I didn’t tried.
Best way is to buy a empty nxp and try to flash using jlink or similar.
Col19 (25th January, 2020)
yes i do have bin aswell for new nxp, all repairs states to try sd card method first... will research that solution after i try sd card method first. i was also told for xprog5.0 to buy new atmega64 chip to update to new xprogm 5.5 but i did it without hassles so lets hope my luck dont run out . thanks for the info though. i have tried reading sd card and pics up as corrupt so hope its only that
so i took sd card out and read on pc, say corrupt, so i format and it works, i load sd files and put it back in ktag but when i take it out of ktag its corrupt again. is this due to nxp that is locked?
inside forum:ask me about...i will tell you all that i know
make me working for you...i will give you my paypal account
outside forum:
chiptuning,egr,dpf,add blue,dtc,Eu clones
PierreTheron (4th August, 2021)
How to write IMG file to SD CARD. With what program did you make copy of SD card ?
Thanks for share
Envoyé de mon SM-G935F en utilisant Tapatalk
Hello all !
For those who use the "custom CID method" with a CID programmable SD card "Samsung" or "Chinese" :
Here is a 7.020 SD card image identical to that of post 1, but I re-encrypted it with a much easier CID.
I did not generate this file with a manual solution, but with my own script.
Thanks to svvag2000 for the original image !
1) You just need to change your SD card CID to : 123456789ABCDEF123456789ABCDEF00
(For Samsung evo SD card : With "evoplus_cid" or "mmc32" under Linux or Android, with super user privileges).
(For China SD card : With the specific Chinese software).
2) Write this SD card image to your SD card with "ImageUSB" or "Win32 Disk Imager"
NO PASS
AGK (4th October, 2018), artkiani (12th January, 2019), Avega1984 (19th January, 2020), bahlawi (19th August, 2019), daniel guerra (19th February, 2018), datapage (19th February, 2018), geris1978 (13th June, 2018), GianniNOS (20th February, 2018), jassoyer (20th September, 2022), konq100 (6th February, 2018), laurent2 (22nd February, 2023), MANGAESY (29th July, 2018), mdanilo55 (8th November, 2018), pagautas (17th February, 2018), radioman (20th November, 2018), SEM (16th August, 2018), subas (26th March, 2019), svallecilla (4th April, 2018), Tomate (21st March, 2019), tyrystor (1st March, 2018), Zibbo (16th May, 2019), Zohar (16th March, 2018)
Hello, I have a red ktag 7.020 clone and obd cable adapter 144300T108 , but it does not work
I saw a friend having ksuite v2.44 and ktag with obd adapter and worked very well, do you have any idea what the connection is?
