Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 49
  1. #31
    I think is about software version, need ksuite 2.41 or ksuite 2.42 thanks a lot.
  2. #32
    kitnoos2002's Avatar
    Sep 2015
    Thanks to svvag2000 for his 2 SD card images.
    But I want to inform you that there are problems in the 16MB image version.
    4GB SD image OK
    "KTAG_7.020_SDcard.img"
    08/01/2018 with size 3,76 Go (4 041 211 904 octets)
    CRC32 : 11F61C9D
    16MB SD image NOT OK
    "7.020.img"
    25/01/2018 with size 15,2 Mo (16 000 000 octets)
    CRC32 : 8D607675
    Example : Euro SD image __VS__ svvag2000 16MB SD image
    (Tested on Samsung Evo with CID 035344535330344780399b1368010300)
    So I advise you not to use the 16MB image because there are bugs in it.
    Use the 4GB version instead, or use the Euro version.
    __________________________________________________ ________
    I generated another SD card image with an easier CID, based on the 4GB SD card image.
    1) You just need to change your SD card CID to : 123456789ABCDEF123456789ABCDEF00
    (For Samsung evo SD card : With "evoplus_cid" or "mmc32" under Linux or Android, with super user privileges).
    (For China SD card : With the specific Chinese software).
    2) Write this SD card image to your SD card with "ImageUSB" or "Win32 Disk Imager"
    NO PASS
    THANKS + REP if I help you
  3. The Following 22 Users Say Thank You to kitnoos2002 For This Useful Post:
    alaabastaki (19th September, 2019), artkiani (12th January, 2019), bajad (1st August, 2018), bali motor (21st August, 2018), dungkenss (7th September, 2019), garciaefren (2nd March, 2022), Jerry15 (7th August, 2018), Jose Santana (23rd April, 2019), kvalentino (5th February, 2020), Luis73 (17th October, 2019), mdanilo55 (8th November, 2018), moky (15th October, 2018), nakamichi (21st October, 2018), niwat_spp (27th February, 2018), paolo poppi (23rd February, 2020), prusony (9th September, 2019), SEM (16th August, 2018), Sergei1956 (8th August, 2018), svallecilla (4th April, 2018), techardware (20th February, 2018), Yhoni (16th August, 2020)
  4. #33
    Mar 2016
    Sweden
    Default ktag
    so on which CID should be changed to this 035344535330344780399b1368010300 or to this 123456789ABCDEF123456789ABCDEF00 ???
    it's important k-tag is green or red ???
  5. #34
    Sep 2015
    Smile
    It's the same files, encrypted for 2 different CID.
    I can encrypt any SD file for any CID.
    Use CID 035344535330344780399b1368010300 for the svvag2000's file
    or
    Use CID 123456789ABCDEF123456789ABCDEF00 for my file. (easier CID)
    KTAG_7.020.bin and KTAG_7.020.hex are exactly the same but presented in another way.
    With flashmagic you need to select the .hex version.
    Green or red make no difference.
  6. #35
    Feb 2015
    Can you post img and CID for 2GB sd-card ? Thanks!
  7. #36
    galiza's Avatar
    Jun 2011
    Default Links down
    Hi, i was looking to update, but all links are down. Maybe someone can reup, please.
    It is better to arrive 10 minutes early, than to be bored all the way.
  8. #37
    Dec 2017
    Quote Originally Posted by kitnoos2002 View Post
    or
    Hi! If I send you my cid, could you make me an sd-image?
  9. #38
    Oct 2010
    can someone reupload files from post #1?
  10. #39
    Jan 2018
    great work
  11. #40
    Aug 2019
    Hi, what can i do to get the files needed for the sd card image on ktag 7.020
    accidentally did the internet thing and my ktag shows internet disconnected, kess works fine.
    with ktag on ksuite 2.23 loads but all the vehicles are gray.
    I have been on every corner of dk to try to get that file.
    thanks for your time.
  12. #41
    Jun 2013
    EU
    Quote Originally Posted by Avega1984 View Post
    Dig there
    Kess 5.017 how to read SD card or create a new SD card
    https://r.tapatalk.com/shareLink/top...ink_source=app
  13. The Following 2 Users Say Thank You to morgano For This Useful Post:
    Avega1984 (19th January, 2020), gory21 (18th March, 2020)
  14. #42
    Jul 2019
    Espaņa
    hello very good Please.
    Could you pass me file sd of ktag v7.020 Greetings.
  15. #43
    all links death
  16. #44
    Jun 2009
    Pleas pass.Thank you!aautista@gmail.com
  17. #45
    Newmotors's Avatar
    May 2019
    brazil
    can someone send the solution?
