Results 1 to 11 of 11
    super jumbe's Avatar
    Livingstone
    Default Deferent between ECU is Z13DTJ and Z13DTH possible will it work?
    Lads I have in garage 2008 VAUXHALL CORSA D 1.3 CDTi with ECU water damaged, the number is Z13DTJ
    (1) Corsa D ECU 1.3 CDTi Diesel 55198930 CN
    Is it possible to programme another ECU with deferent number this one Z13DTH?
    (2) ECU CORSA D 1.3 DIESEL 55566039 HK Z13DTH
    Basically the damage ECU is Z13DTJ and the new one I have got is Z13DTH is it worth programming?
    Thanks in advance.
    KILL_THE_IMMO's Avatar
    spain
    i m asking too for long time difference between y17dt and y17 dtl and y17dth
    --------HELP OTHER TO BE HELPED--------------
  3. The Following User Says Thank You to KILL_THE_IMMO For This Useful Post:
    super jumbe (15th January, 2018)
    Livingstone
    What ever has any one managed to programme successfully?
    I heard if you change the full kit it should work can any one confirm that.
    smokey08's Avatar
    Essex, UK
    I have a car with this problem too. My ecu is 55563498. I cannot find an identical replacement anywhere. In someone has a list of compatible part numbers it would be appreciated.
    Jul 2013
    yorkshire
    I think its because the engines are slightly different, One has flaps, one has dpf, one has electronic egr. So it may start the engine, BUT you wil alwaysl have fault codes for the missing units.
    Livingstone
    Told if they are similar serial numbers they should work I will let you know the result once I get hold off them…
    ENGINE CODES: Z13DTJ
    HARDWARE LEVEL MAGNETTI MARELLI UNIT
    MJD 603.S3 HW03A
    YOUR UNIT MAY HAVE ONE OF THESE OLD PART NUMBER
    55198930 CN
    55568383 KZ
    55568382 KY
    55566039 HK
    55198931 CN
  8. The Following 2 Users Say Thank You to super jumbe For This Useful Post:
    BusCan (13th April, 2018), smokey08 (17th January, 2018)
  9. #7
    Aug 2010
    So I Test it
    you can change all if you have the same hw ; like in your case mjd603.
    i read the org Eeprom and flash for a Corsa d and clone a other Opel number ecu with this Data . It works fine
    you can clone it with Abritus AVDI org by OBD
  10. The Following User Says Thank You to JFR-Tuning For This Useful Post:
    super jumbe (20th January, 2018)
  11. #8
    Livingstone
    Thanks your idea noted, as I have noted on ebay there is a ECU repair service and giving lifetime warranty any one used this service and had ECU repaired successfully.
    VAUXHALL CORSA D ENGINE ECU
REPAIR SERVICE
    https://www.ebay.co.uk/itm/vauxhall-...653&rmvSB=true
  12. #9
    Sep 2016
    south africa
    Quote Originally Posted by KILL_THE_IMMO View Post
    Same. You can program
    Sent from my SM-A515F using Tapatalk
  13. #10
    Sep 2016
    south africa
    Quote Originally Posted by super jumbe View Post
    Correct
  14. #11
    Sep 2016
    south africa
REPAIR SERVICE
    Absolutely no one van Give a lifetime guarantee. So u would not trust this site.
