I had similar problem, i tried all calculators that are available to download without success , member @hid3 helped me which gave correct coding very fast, i advise to contact him
Hi, please help with ABS long coding Audi A3 2010 tdi
Removed dash and lost codding on ABS, now all 000000000000000000
Please help ....... Can donate for working solution
Tuesday,16,January,2018,13:36:09:54500
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 17.8.0.1
Data version: 20170721 DS276.2
www.Ross-Tech.com
VIN: WAUZZZ8P7AA132636 License Plate:
Mileage: 80000km-49709mi Repair Order:
Chassis Type: 8P-AU35 (1K0)
Scan: 01 03 09 15 16 17 19 25 42 44 46 52 56 61 62 69 72
VIN: WAUZZZ8P7AA132636 Mileage: 80000km-49709miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: Cannot be reached 1100
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CFFB) Labels:. 03L-906-018-CFF.clb
Part No SW: 03L 906 018 AB HW: 03L 906 018 AG
Component: R4 2.0l TDI H20 9979
Revision: 41H20--- Serial number: AUX7Z0J1FN80VU
Coding: 00190010040401080000
Shop #: WSC 38406 002 1048576
ASAM Dataset: EV_ECM20TDI01103L906018AB 003012
ROD: EV_ECM20TDI01103L906018AB.rod
VCID: 6ADA4F0C8DAB0D1634-803E
1 Fault Found:
5250 - Function Restriction due to Faults in Other Modules
U1113 00 [039] - -
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Mileage: 80000 km
Date: 2018.01.16
Time: 00:04:53
Engine speed: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 32 °C
Intake air temperature: 11 °C
Ambient air pressure: 990 mbar
Voltage terminal 30: 12.420 V
Unlearning counter according OBD: 40
ACC control module received status-Bit 0: 00000000
Status of ACC/CCS acceleration interface-Bit 0: 00000000
Acceleration: 0.000 m/s²
Engine status: COENG_READY
Cruise Control System (CCS): status-Bit 0: 00000000
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AJ HW: 1K0 907 379 AJ
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
Coding: 00000000000000000000000000000000000000
Shop #: WSC 26815 002 1048576
VCID: 7AFA7F4CF50BBD96C4-802E
2 Faults Found:
01042 - Control Module; Not Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 19
Time Indication: 0
Date: 2018.01.16
Time: 00:04:17
Freeze Frame:
Count: 3
Count: 0
Count: 20992
Count: 195
Count: 44288
Count: 0
Count: 0
Count: 0
00778 - Steering Angle Sensor (G85)
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 19
Mileage: 80000 km
Time Indication: 0
Date: 2018.01.16
Time: 00:03:41
Freeze Frame:
Count: 3
Count: 0
Count: 20480
Count: 295
Count: 44544
Count: 65280
Count: 256
Count: 0
Address 09: Cent. Elect. (J519) Labels:. 8P0-907-063.clb
Part No SW: 8P0 907 063 A HW: 8P0 907 063 A
Component: BCM PQ35 M 105 0575
Revision: 00105 AK
Coding: 06000A2FB0051AC0207040E00100015C437A29AA006D4522E4 008F800041
Shop #: WSC 06314 000 00000
VCID: 326A976C6DFB85D64C-8066
Subsystem 1 - Part No SW: 8P1 955 119 F HW: 8P1 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H10 0040
Coding: 00DD13
Subsystem 2 - Part No SW: 8K0 910 557 HW: 8K0 955 559 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSEN H04 0003
Coding: 024C2D
1 Fault Found:
01517 - Control Module for Trailer/Towing Sensor (J345)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 19
Mileage: 80000 km
Time Indication: 0
Date: 2018.01.16
Time: 00:04:51
Freeze Frame:
Term 15 On
Voltage: 12.40 V
ON
ON
Term 50 On
OFF
OFF
Address 15: Airbags (J234) Labels:| 8P0-959-655-10.clb
Part No SW: 8P0 959 655 P HW: 8P0 959 655 P
Component: Airbag AU1042 H06 0160
Revision: -------- Serial number: 003FB005HRD5
Coding: 30314238303830303035554A304C38503053
ASAM Dataset: EV_Airba10AURB4 001001
ROD: EV_Airba10AURB4.rod
VCID: 4FACFE981609C83E43-801A
Crash sensor for side airbag: driver side:
Serial number: 3572DRB40000AAAC79FG
Crash sensor for side airbag: front passenger side:
Serial number: 3582DRB40000AAC10B0V
Crash sensor for side airbag: rear: driver side:
Serial number: 35128RB40000561A1C3D
Crash sensor for side airbag: rear: passenger side:
Serial number: 35228RB400005610EBCP
Crash sensor for front airbag: driver side:
Serial number: 35547RB400005603B0FK
Crash sensor for front airbag: front passenger side:
Serial number: 35647RB400005603B3DM
No fault code found.
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 DB HW: 1K0 953 549 DB
Component: J0527 037 0070
Coding: 0000012
VCID: 75E06C701C15D2EEA9-8020
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 932 C HW: 8P0 920 932 C
Component: KOMBIINSTR. VDO H03 0990
Revision: D0H03005 Serial number: 2241J005048496
Coding: 0004028
Shop #: WSC 65536 004 1082875
VCID: 3466917457EF8BE65E-8060
Address 19: CAN Gateway Labels:. 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 AF HW: 1K0 907 951
Component: J533 Gateway H17 0233
Revision: H17 Serial number: 1521J10204060B
Coding: E9807F42000202042102
Shop #: WSC 45728 001 1048576
VCID: 6BD44A084A51141E4F-803E
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 19
Mileage: 80000 km
Time Indication: 0
Date: 2018.01.16
Time: 00:04:57
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D0H03005 Serial number: AUX7Z0J1FN80VU
Shop #: WSC 00000 000 00000
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8P0 959 801 N HW: 8P0 959 801 N
Component: Tuer-SG H04 0100
Coding: 0131220
VCID: 4682DBBC31730976F0-8012
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 232 3001
Revision: 00H17000
Shop #: WSC 02069 000 90108
VCID: 31689860A8FDBECE35-8064
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
Part No SW: 8P0 959 802 N HW: 8P0 959 802 N
Coding: 0131220
VCID: 479CD6B83679107E0B-8012
Address 56: Radio Labels: 8J0-035-1xx-56.clb
Part No SW: 8P0 035 186 AB HW: 8P0 035 186 AB
Component: R Concert2+ H05 0293
Revision: 00H05000 Serial number: AUZ1Z3M3015158
Coding: 0710011
VCID: 72EA576C6D7BC5D68C-8026
1 Fault Found:
01303 - Telephone Transceiver (R36)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 19
Mileage: 80000 km
Time Indication: 0
Date: 2018.01.16
Time: 00:07:45
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 1K0 907 534 HW: 1K0 907 951
Component: Batt.regelung H17 0233
Revision: -------- Serial number: 1521J10204060B
Coding: 0303085A
VCID: 68DE35049BA73F0622-803C
Subsystem 1 - Part No SW: 1K0 915 181 C HW: 1K0 915 181 A
Component: J367-BDM H07 0125
Serial number: 00000000002790991769
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No SW: 8P4 959 801 F HW: 8P4 959 801 F
Component: Tuer-SG H04 0050
Coding: 0131216
Shop #: WSC 06314 000 1012544
VCID: 428AC7AC1D5B3556DC-8016
Address 69: Trailer
Cannot be reached
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No SW: 8P4 959 802 F HW: 8P4 959 802 F
Coding: 0131216
VCID: 4384C2A802413C5ED7-8016
End-------------------------(Elapsed Time: 02:21)--------------------------
Address 17,8P0 920 932 C,channel 53,adapted from,450,to,0,
darius89 (16th January, 2018)
try that one: 11424012092500FC881102E7901F0041390800
