Page 15 of 268 FirstFirst ... 510111213141516171819202565115 ... LastLast
Results 211 to 225 of 4016
  1. #211
    Aug 2015
    Is there any timetable for 2012 2013 mqb cluster? Is it common car now.
  2. #212
    Feb 2017
    Quote Originally Posted by lupu_sandu View Post
    Mercedes Vito early model (W639) with 908 MCU, avdi after 90 minutes still cannot pull pass out from EIS using fuse relay and DS Box (tested on 2 cars).
    Send mail to support, Alek reply to me that is impossible and to send my SN from AVDI to check, then no more reply. End of story.
    Still have to pull that EIS to read (a pain in the a*s)
    I have successfully extracted the key password today from a W639 EZS for about 60 mins.
  3. #213
    Feb 2017
    Quote Originally Posted by offsystem View Post
    Yes, it is.. We will probably have a solution very soon but unfortunately I cannot name any time frame at the moment.
  4. The Following 2 Users Say Thank You to ventzy For This Useful Post:
    clearly (18th March, 2018), topclef (21st February, 2018)
  5. #214
    V.I.P. Master of the IMMO
    lupu_sandu's Avatar
    In my immobox...
    Quote Originally Posted by ventzy View Post
    With or without DS box?
  6. #215
    I have encountered the same problem if all KEY LOST (or replaced the second EZS without the key) do not work through the relay distributor box.
    I solved another method in 40 minutes with the AVDI + IR reader via OBD
  7. #216
    Aug 2016
    Quote Originally Posted by BADBOYS_FOREVER View Post
    Where can i get a benz IR reader?
    Sent from my SM-N910T3 using Tapatalk
  8. #217
    Feb 2017
    Quote Originally Posted by lmqcatarino View Post
    I already read a few pin codes from recent PSA cars, but when is older cars, it allways loop on ignition on - ignition off - on - off... There is something i should do?
    Enviado do meu MI 6 através do Tapatalk
    There should be a problem in the connection to pin 3 and pin 8 through the OBDII. Please check the voltage of both pins - it should be between 2-3V.
    If the software is not able to connect to the BSI it tries to read the PIN code from the Engine ECU, but the older models do not even provide connection to the Engine ECU through the OBDII (pins 6 and 14 are missing/disabled).
    So I would suggest to first check if you have a communication with the BSI, if you have it but the software still tries to read the PIN code from the Engine ECU we will need to analyze the log files.
    If you don't have connection to the BSI you could always connect to the Engine ECU CANs directly using the Distribution box and read the PIN code from it.
  9. The Following 2 Users Say Thank You to ventzy For This Useful Post:
    clearly (18th March, 2018), lmqcatarino (23rd February, 2018)
  10. #218
    Feb 2017
    I used a DB in order to connect to the K-line and use its relay for faster password extraction (and no manual reinsertion of the IR-adapter).
  11. The Following 2 Users Say Thank You to ventzy For This Useful Post:
    lupu_sandu (22nd February, 2018), Talleresmalaga (30th October, 2018)
  12. #219
    Feb 2017
    Quote Originally Posted by purplecty View Post
    It is the IR-adapter (ZN036) which comes with MN026 Special function. You could also order it separately either from the online store or your local dealer.
  13. #220
    Dec 2010
    Nottingham
    Valid question.
    but do we know the answer , is it a free update if you have latest licence and ams , or will it be a paid for addition ? . well done as well , i look forward to using this new function . thanks for info.
  14. The Following 2 Users Say Thank You to rapidlocksmiths For This Useful Post:
    clearly (18th March, 2018), ventzy (21st February, 2018)
  15. #221
    Feb 2017
    Quote Originally Posted by rapidlocksmiths View Post
    It was not a question
    PIN reading and Key programming will be assigned with the PN016 Special function. This will be free for all customers who have PN014 and a valid AMS as of February, 21. 2018. If the AMS is renewed after February, 21. 2018, the update to from PN014 to PN016 costs an additional 200€ (without VAT).
    Cluster and BSI calibration will fall under the PN015 license which can be upgraded from PN013 for 200€. AMS is obligatory in this case also.
  16. The Following 2 Users Say Thank You to ventzy For This Useful Post:
    gttuning (21st February, 2018), rapidlocksmiths (21st February, 2018)
  17. #222
    koln, germany
    we are kindly asked to pay for every things !!!
  18. #223
    Feb 2017
    Quote Originally Posted by isma123 View Post
    Let's please not discuss the prices and compare them with others and focus on the technical issues only.
    Thank you.
  19. The Following 8 Users Say Thank You to ventzy For This Useful Post:
    clearly (18th March, 2018), gttuning (21st February, 2018), joemajdalani (21st February, 2018), lupu_sandu (21st February, 2018), rapidlocksmiths (21st February, 2018), shafo (21st February, 2018), ThiagoArgentino (22nd February, 2018), yugo45 (21st February, 2018)
  20. #224
    Dec 2010
    Nottingham
    excellent news thanks
  21. The Following 2 Users Say Thank You to rapidlocksmiths For This Useful Post:
    gttuning (21st February, 2018), ventzy (21st February, 2018)
  22. #225
    Mar 2017
    Ran some more toyota unlocking test. Turns out that AVDI does partially unlock key and it will program as new onto another vehicle. Problem I was comparing it to MK3 which actually does a FULL erase of the key.
    So when I was unlocking my own vehicles key the following was the issue.
    avdi = key partially unlocked(one blink on light). Remote still works and it start vehicle by putting key againt button. The prox features do not work and you can not program key back into vehicle. This key can be programmed onto another vehicle with zero issues.
    mk3 = key fully erased(six blinks on light). The key becomes completely useless on the car it was originally programmed to. Can be added back into car as if it was new from dealer.
    So the outcome is AVDI partial unlock is good enough as it can be programmed as new onto a vehicle. Who is going to unlock their working key and program them onto their own car? !!! Only did this to test if key was actually getting unlocked. ;-)
  23. The Following 5 Users Say Thank You to ps80l For This Useful Post:
    autocar88 (8th July, 2018), clearly (18th March, 2018), lagaffe (22nd February, 2018), rapidlocksmiths (22nd February, 2018), Talleresmalaga (30th October, 2018)
