Did anyone try to write VW MD1CS004 2019 with Avdi ?
I have asked support and they told me that they
can NOT confirm whether it will be safe since there are a different pins
on ECU.
on ECU.
Hi, anyone know avdi BMW online software for Bike K63 2022 that lost all remote have solution or no ? i check it with last version 34.7 but software message only show me "Checking unit version ..." anyone know what is the problem ?
prod date: 11.2021
Engine A67 ( S1000R )
DME: BMSO1 (SWFL - 00005F16-030.000.000 )
X_SLZ (EWS): (SWFL - 00000BFD-003.008.003 )
Remote key type: XM38
avdi he does not know keyless and mecanical 8A , I had to buy a tool from China anly for moto to add keys and all key lost unexpectedly good .
wuza (14th April, 2024)
is there a problem with precoding on iveco daily 2015 vans? i used IEA Fir134+ remotes, on 2 Daily vans,Delphi system, first one only light were flashing, the second one, only side and back door locks or unlocks, with Marellie, no remote function, has any one else had this experience.
I have used these on relay, Boxer with no problem, thanks
ive done alot of iveco daily , all were marelli , never had one fail with avdi , i use oem boards in my own cases , all spot on.
As i mentioned above Martin, i did try Marelli, but no reaction from the remote, on Hickleys site they mention that these are Delphi system!! , but thanks i will try this next time.what year were they?
all between 2014 and 2020 models , done around 40 in last year as well as 8 top end motor homes 2015 to 2019, all were marelli .
i stick to oem boards , bought alot from mk3 till they run out and then bought from sos.
Thanks, told the guy to come back ,after holidays, will update.
Lets all not forget that they remove some features that we have already paid for as they please......At this point i believe is just ruthless and greed on Abrites side..I have a valid AMS and i am sure there are thousands more you do the math on how much they get on AMS alone per year,I expect them to treat us better....
ford and mazda still trash i see
thought would give it one last chance just to see how it has developed.......
oh me a long way to go yet avdi
and the eprom functions for making a key from dump
vvdi still blows it away let alone tango but thats another thing thats been left on the shelf for years ........
any development on MG yet probably last company to look at this
@ Martin, you were correct, changed the remote mode from Delphi to Marelli, reprogrammed, and remote worked, then used the key tool to sniff pass, to unlock the 2 remotes that i waisted back to unlock.cheers
ps. told supplier to edit these from Delphi to Mrelli type.
rapidlocksmiths (29th March, 2024)
@Nazz2 , yes poor of hickleys not to make this clearer , though if the key that is for both systems then i guess the key covers both delphi and marelli if set to correct one. glad its sorted
auto techniek (4th April, 2024)
hello
i trz to make key on 2016 bmw 220 but when I unlock bdc on end it ask me to write Net data and that failed
so anyone know how to write NCD file back as now I have some error #18
regards
