lush29 (11th April, 2024)
Can also carry out personalization on ECU, done 3 jobs so far, 1 on car 2 on bench
lush29 (15th April, 2024)
Hyundai/Kia fantastic thanks Abrites
Now codes seem to be so expensive /unavailable we need this kit more than ever
Solidarity with Ukraine
lush29 (16th April, 2024)
hello to all of you , has anyone had the opportunity to do it with RH850/v850 MQB AKL keylessgoo , thanks .
hello guys. I have a mercedes ML 2001 with start error. I follow these steps but get stuck at no.4. Arbrites say it could be faulty or wrong transponder 7935. Where does READ CONFIG DATA fall in this process.
Also if i fail OBD and try on bench, i read eeprom and then what next (eeprom already read with xprog ) TIA
1. open mb sw offline and go to das2b (w163)
2. open learn radio code to see which key is already written and ensure terminal 15c is ON
3. exit and go to TRANSPONDER GENERATION and choose PROGRAM ML TRANSPONDER
4. this is where im stuck and tool say PLEASE WAIT on the scroll bar below. It does not complete the programming for me to go the next step of LEARN TRANSPONDER.
You can try and prepare the transponder using the Tag Key Tool function. On the menu where you choose the Mercedes function go all the way down. There you will see the Tag Key Tool fucntion. In there you have a "prepare transponder" subfunction. Coose ML and prepare the chip. If that works you can skip part 4 and go straight to programing with your prepared tranponder.
sagie (29th April, 2024)
hi, thanks for the assist. i did try this few days ago and again today with 7935 chip It starts to program and then says CANT WRITE SECTIONS . Does this mean the transponder is wrong or faulty
I am guessing that you are using an aftermarket version of a PCF7935 since NXP stopped production of their original type. So my guess would be that the transponder you are using is the cause as I personally have been unable to find a good replacement to cover my needs (disregard the people reccomending XT15 as the coverage of that is hit or miss at best).
