Is it worth to buy mqb key learning, or is vvdi2 also doing it?
VVDI2 better at this, it seems.
Also with AUDI A4 2007+
avdi failed to reset smart key ecu on 2005 Toyota Avalon with all keys lost. failed to make emergency start with emulator. one big total failure. in the end job was done with obdstar x100. i know avdi is a useless tool but not that much.
2016 kia sportage regular key..
Pin read fail...
Im getting bit frustrated at this stage...
I have not one success on kia hyundai from 2016 upwards with new update...
Any one had at least 1 successfull immo pin reading?
Sent from my SM-G955F using Tapatalk
Auto Locksmith,Tuning,Dpf Removal,Dtc Removal,Immo Removal,Ecu Adaptation,Crash Data-Clear.
Some new things are coming... (attachment)
*Range Rover Evoque 2017 - spare key programming ok
*Range Rover Evoque 2017 - mileage doesnt work
*Hyundai Coupe 2008 2.0l - reading pin doesnt work (ID46)
*Hyundai Coupe 2008 2.0l - no communication with immobiliser (launch programming key with knows pin)
*Ford Transit Custom 2018 AKL - key programming doesnt work (ID47)
*A lot of troubles with BMW online - lost FEM coding after key programming, flashing unit doesnt work sometimes, missing useful functions(time setting in airbag satellite system), I still need to use winkfp ncsexptert tool32 inpa ista to finish the job
Hi mates,
I´m triying to read ISN on MSD81.2 on bench but I cant. Is it necesary connect cas3 on bench for that?
Thanks in advance
no. not all msd vertions is supported
alclot (11th December, 2018)
Hi i have question to Peugeot / citroen functions from avdi
PSA BSI Exchange set- Special functions PN015 and PN016
Is it working good also in latest 2018 cars??
Hello to all the professionals. The USB port on my unit was damaged so I went ahead and replaced it. Now the software is not recognizing the interface. Is there anything that can be do to solve this issue?
Sent from my SM-G930F using Tapatalk
Maybe it was not only the USB port that got damaged.
Return to your dealer.
trinicolin (13th December, 2018)
Can anyone confirm the Subaru new or used ECU adaptation by AVDI?
