show me the software you are using
with version
they are not released yet
prrof in picture
Auto Locksmith,Tuning,Dpf Removal,Dtc Removal,Immo Removal,Ecu Adaptation,Crash Data-Clear.
with version
prrof in picture
gttuning (3rd February, 2019), PocketHero (3rd February, 2019)
Abrites wont read VDO in A3 1.6 pcr2.1..
Dont know why but security accsess fail.and worst is its pcr2.1 cant read unless its unlocked...
Once tuning tools released pcr2.1unlock by obd i tough that will speed up process but once you write flash by obd and ecu status shows unlocked with X17 abrites still see as locked....so i have to take ecu out and unlock on benchi use fgtech for that.
Sent from my SM-G955F using Tapatalk
PocketHero (3rd February, 2019), yugo45 (6th February, 2019)
Yes..precode key and learn with abrites A3 CAN..
But if you be doing this next time with abrites in pcr2.1 ecu...once you get cs from ecu you have to find 7th byte from working key...this works ok but once you see 7th byte... for example "A2"
Typ this manually couse if you let abrites prepare key it dose wrong..in my case it put 80 instead A2..so you have a window to preper key with all known CS use that and manually typ in all 7 bytes and then works ok..after that just learn key with pin. with abrites or vcds.
offsystem (3rd February, 2019), PocketHero (3rd February, 2019)
who read fbs data from ecu crr1? renault engines ?
Hi all.
buy the soft VN004 recently and today try to read an ecu EDC17c46.
the connections as shown in the manual and using (box distribution)
but nothing, I attach a photo of the error.
try also to read it with a configuration of other manuals and nothing the same.
Thank you
Did you connect T1 and T2 wires from from distribution box ?
next time abrishit starting playing with license - look at vag and mercedes... they are the master of making new license number with the same function!
nenadgorgi (5th February, 2019)
[QUOTE = pepi; 3492798] Did you connect T1 and T2 wires from from distribution box ? [/ QUOTE]
thanks for answering
the manual says nothing about connecting those cables
Hello, can you hel me please!!! Needing the keycode of my key ( pin of key ) for my Hyundai Veloster model 2013
Vin : KMHTC6ADXDU179425
