Kia Hyundai pin reading for new models like Tucson is need it.....please abrites team.
Sent from my SM-G935F using Tapatalk
Auto Locksmith,Tuning,Dpf Removal,Dtc Removal,Immo Removal,Ecu Adaptation,Crash Data-Clear.
Hello lads
I have a problem with cloud. No matter if I choose Merc cloud bmw cloud mini or dacia I just get a failed opening of the software. I have tried direct to open as admin in program files. Same results. Screenshot attached. Emailed kap whom told me I don't have a support plan so they basically will not help me. Spoke to Abritus who told me to speak to kap. My AMS is valid and I have just installed to the lastest Jan 2018 release. I've even installed on a different machine with a fresh 7 install tried on Wi-Fi and tethering same results. Anybody else seen this..
Genuine tools including Abritus, Autotuner Master, Bosch Ford vcm2, smok UCDS FULL JTAG FULL pcm flash, IO terminal, UPA, Autel maxicom pro, MTX dpf, dtc, immo edc17 UCDS, and a little well maintained hairy box from china I play inside!
4.94 x100 fgtech kess ktm ktag mpps skp. And still collecting
This is really strange. Try to reinstall all Abrites software and disable the antivirus program.
It is important to check whether port 8443 is being blocked by your ISP. You could test the cloud software with 3G/4G connectivity.
I would suggest to try on a different PC as well so that you can verify if it is a local issue.
Hello thanks for reply. All you suggest I have already tried. Tethering check new machine check new op system check no anti virus check new Install soft check
norman1967 (31st January, 2018)
just try to learn key for AUDI A3 year 2016 ordered from dealer , still Protag can not detect it .
the best way is to add a button ( dealer's key learning ).
with blank keys , all is well for MQB key learning , amazing and easy , great job
you have two choices in the morning: go back to bed and continue dreaming, or you get up to make your dreams come true
Venty
I have seem problem than normann1967
When will online MB software become operational?
Only diagnostic working since you launched it. W164 ,W211,W251,W204,W203,W639 and W906 tested and if I hit any button except fault codes(DAS,Special,Programm ID) pop-up window appear with message "Not supported in this vehicle"
Guided fault finding = Feature that many factory scan-tools have and real technician despise it.
Vw Beetle, 2001, petrol,9C, ayd engine code failed to pull pin under mm4, and few others.
