Results 1 to 5 of 5
    Sep 2012
    Poland
    Default Smart FourTwo 450 key learning fail...
    I have a problem with key synchronization in a smart FourTwo 450 from 2000. I tried to sync X431 and Fvdi but with no result. I did everything as in the instructions, but the immo light does not flash (when the procedure starts, it should blink quickly). I have two new and two old remote controls. One key is received, but the direction indicators flash quickly 9 times. In Zee, an error occurs that the key is over-role code. Maybe someone had a similar problem. Any other method?
    Autronico2's Avatar
    Jan 2021
    Italia
    Quote Originally Posted by djnovy View Post
    I've always done coding with Texa and I've never had any problems.
    Autronico2's Avatar
    Jan 2021
    Italia
    Have you tested the frequency of the remote control if it is correct?
    Sep 2012
    Poland
    Quote Originally Posted by Autronico2 View Post
    Yes frequency is correct.... only problem car don't go to sync mode...
    Key indicator no blinking fast...
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    in fvdi are many mercedes versions...
    after choose brand smart or mercedes...
    and you can choose version...
    select oldest version...
