Anyone who can
Anyone who can
File is wrong readed, read again.
Post also ecu model and ecu id.
Sedat Garip
Chiptuning Remapping, file service, stage 1 & 2 dyno tested.
Diesel + petrol All cars
Manual Adblue dpf egr Opf tested working solutions
Belgium
With Kind Regards,
Don't forget hit thank button if i helped.
Tedum (18th January, 2018)
File readed with kess by obd and its ecu is sim4le
Can you post ecu id numbers
File is empty.. Try open in winols you see only FF
Sedat Garip
Belgium
With Kind Regards,
Tedum (20th January, 2018)
Try to read this file with galletto without problem can read and write ,this is empty bad readed
Proffesional ECU & TCU Tuning
Petrol and Diesel Engines
File Service
here is my file read with galleto
make my accelerator pedal response better and gain from 120 to 140hp , also if possible make my radiator fan to run before 90 degree like 70 degree at medium speed
Any help
will send thanks + rep
Wrong read mate..
Sedat Garip
Belgium
With Kind Regards,
