Page 1 of 4 1234 LastLast
Results 1 to 15 of 63
Hybrid View
    Jul 2016
    Default help pls cas3+ synchro not possible after add key with avdi
    hello
    pls i try to add key for BMW X6 cas3+ with AVDI it show me no working detected and the car was starting after i start it with the original key the car it show me same thing so i continue the programing the new key open ignition and turn the engine but without starting the car and the original key didnt open the ignition again
    attached the dump from the cas
    ps: i try to add the key to number 0
    thanks for helping
    Dec 2017
    Poland-Germany-Ukraine
    it seems u made second key on the place of ori key, because u have only one key active.
    Jul 2016
    yes i think that but what is the solution now pls
    dijo's Avatar
    Apr 2010
    Hi, post here an image of Hitag-pro from your first and Ori key...
  5. The Following User Says Thank You to dijo For This Useful Post:
    cyril (18th January, 2018)
  6. #5
    Jul 2016
    HELLO
    thanks for u r reply attached the photo i was able to get with high tag
  7. #6
    kiszka's Avatar
    Aug 2009
    Reality of life :
    1:Never argue with an idiot, he will pull you down to his level and overcome you with experience
    2:Envy is the confession of inferiority
    3:Everyone lies
    How much trash you leave behind so much trash someone will have to read or maybe you yourself
    If you like reading garbage, don't slow down, just speed it up
  8. #7
    Jul 2016
    so what can i do pls ??
  9. #8
    Dec 2017
    reset 2 keys , read isn dme and then make keys with tango or avdi
  10. #9
    Jul 2016
    HOW TO RESET THE 2 KEYS PLS AND CAN ABRITUS READ THE ISN DME ?
  11. #10
    Dec 2017
    Quote Originally Posted by cyril View Post
    I think with such questions better give car for somebody else to do it.
  12. #11
    kiszka's Avatar
    Aug 2009
    Reality of life :
    3:Everyone lies
  13. The Following 2 Users Say Thank You to kiszka For This Useful Post:
    ALBERTO_ (20th January, 2018), luis12 (20th January, 2018)
  14. #12
    Jul 2016
    hello i try the file it didnt open ignition on the original key and on the new key programed before it do same thing it turn without starting and cant synchronize
  15. #13
    dijo's Avatar
    Apr 2010
    M8, you have 2 chances as other Guys says, read ISN/SK from DDE and make new key...
    or trying to unlock your transponder to get page3
    write in your Hitag-Pro screen this=
    SK High = 22E2
    SK Low = 0D73C04B
    with this 2 codes you will unlock your tranponder and read "Config" code...
    if it works post here this code...
    if not...
    read ISN/SK from DDE...
    "this all only because you overwritten your existing key"
  16. The Following User Says Thank You to dijo For This Useful Post:
    Sidemark (18th January, 2018)
  17. #14
    Dec 2017
    Quote Originally Posted by dijo View Post
    SK High = 22E2
    SK Low = 0D73C04B
    if not...
    I think avdi can not do this, may be im mistaken. I know two good tools that can show all key info - PSW in that case
  18. #15
    dijo's Avatar
    Apr 2010
    AVDI-Online can do it with License...
  19. The Following User Says Thank You to dijo For This Useful Post:
