Bad reading. Best way is to desolder.
Hi all I wonder if some kind member can assist with where i'm going wrong trying to read and write this smart sam unit please from a smart roadster 2004 I am having trouble reading correctly smart sam with upa and vvdi prog. Upa read correct but the file size is incorrect. I have used connections posted by member Pipnina(Thank you) on here and have virgin flash ect but when I try reading flash I only get 64kb file I know should be 2048kb. I have lifted pin and had to put link wire in due to it being knocked and lifting a pad on the board. Btw genuine upa. Here are attached dumps
Eprom - This looks okay
flash - wrong size and not the same
flash 2 - wrong size and not the same
Flash V0.13 Flash from this forum notice 2048kb mine is only 64kb.
Also images attached.
ahh yes but many people have read these with out desoldering mcu any ideas?
http://www.digital-kaos.co.uk/forums...smart-roadster
And io terminal or Smok, by Obd maybe.
Cheers buddy did read that thread already got a xprog 5.5 here I'll take a look good to know terminal io can do them thanks for the info.
I have tried with these connections still no joy this is with upa
Anyone got any other ideas or connections how I can read and write this sam with either upa orig or xprog clone or vvdi prog?
Hello , you need to use 3.3V in UPA , this kind of MCU use low voltage for working .I think your UPA gives bad contact on VCC , corect ???.Also check your wiring because connection from forum MUST work in circuit .
Hi guys sorry to revive a old thread but still got this car and still having trouble with this sam . Okay today have tried with vvdi prog please find attached dumps. Can anyone help me with this??
Cheers
Galee
