Results 1 to 2 of 2
    Aug 2014
    Default SEAT ALTEA 2008 LCD Display Stays on
    Hi i have a friend told me his altea 2008 2.0 LCD Display in dashboard ( cluster ) stays on after removing the key. I suspect probably something of the circuit board on the cluster or even BSI unit .... or maybe just a fuse ? Anyway i think it sounds bad...
    Havent looked at it yet. Ill take vagcom but i think it wont solve anything , so i think ill check the soldering behind the circuit board at naked eye to start, and if not take that circuit home to look at it carefully for "Suspicious components, or resolder all.."
    Maybe someone already had this case and could point to something ? Thanks and have a nice day !!
    Aug 2014
    Problem Solved. After testing it fail several times opening and closing the car , Measured Battery 10.7 Volt. Changed Battery. Problem Solved.
