Results 1 to 7 of 7
    alfons37's Avatar
    Default Need immo off opel vivaro edc15c3!
    Opel vivaro
    bosch 0281011890
    5p08c
    i Try with emulator but it flashing in cluster
    alfons37's Avatar
    Car start now but i think my files is not good. Speedometer, speedometer and temp meter do not work with my file, someone who can help me and write it right
    alfons37's Avatar
    Must i cut can-l or this connected?
    alfons37's Avatar
    Default switch
    I use julie emulator, and it say and need security switch, must i have security switch?
    alfons37's Avatar
    Now it works but a bad solution, according to julie emulator, you will have installed a switch on the can, and if you have the switch in off (no can bus L), then the car will start but the speedometer does not work because it goes on a can , then everything works, but only i can only recognize the switch when the car is on. Should the car be turned off and the switch is turned on then the car will not start.
    Anyone have solution without switch?
    Lithuania
    What switch?, mount emu to ECU and it works
    rafal's Avatar
    UK - PL
    Quote Originally Posted by alfons37 View Post
    repair car...............................
    car crapt old - so leave swich
    need help
    now my goal is to buy xp-005
    who will help?
