Results 1 to 3 of 3
    Aug 2013
    Default Zgemma H2H audio narration
    Having issues with the box. The box is fully loaded with server and extensive iptv package.
    I've read the box needs to be flash with a new image. Currently using Wooshbuild v6 openATV.
    Can someone give me steps to what I have to do.Where to get the latest build.Also if I flash, will I loose everything on the box.ie server details channels,iptv/including username password etc?
    What's the best way to approach this as when I flash so I can put things back on easily. And have my same set up as previously.
    plasterer's Avatar
    Jun 2008
    Mersyside
    If the audio problem is on the h2h refash
    Will sort it out.
    If audio is on iptv you will need to contact the service provider
    All login details will be lost on reflash
    Hope this helps. .....Paul
    PAUL
    Aug 2013
    Quote Originally Posted by plasterer View Post
    Will sort it out.
    How do I save stuff before hand and put it back. On after flash.
