Results 1 to 4 of 4
    hamzadaw2000's Avatar
    Aug 2013
    Default Ford Mondeo 2013 car will not start after crash
    Is their a fuel cut off switch in Ford mondeo 2013, or like Ford Focus there is a procedure by switching ignition switch 30 seconds on and then off.
    Hi Check the airbag srs system for crash deployment data as it may affect starting
    Fuel cutoff normally in Srs module. Need to clear crash. Also check bcm has crash may be recorded here.
  4. The Following User Says Thank You to radiosolutions For This Useful Post:
    hamzadaw2000 (27th February, 2018)
    In EEP
    Hi finaly you need reset BCM crash dtc this can proper tool laik VCM IDS AVDI Xpro3 ...etc.
  6. The Following User Says Thank You to vasa For This Useful Post:
