yep, I/O for example
Anyone knows of this car is readable/write over obd?
Someone have do this?
I tryed yesterday Volvo v50 1.6d (edc16c34) but no with obd, must to do with BDM. The strange this is, this is the same ecu of psa ford focus 1.6tdci.
And what about Volvo V50 2.0d ?
Sedat Garip
Chiptuning Remapping, file service, stage 1 & 2 dyno tested.
Diesel + petrol All cars
Manual Adblue dpf egr Opf tested working solutions
Belgium
With Kind Regards,
Don't forget hit thank button if i helped.
Volvo Electronics Enginering
CEM Config change, virginize modules , keys programing...
there is installed Siemens sid 803 volvo v50 2.0d
Terminal and uhds full by obd.... Kess read write to special cable Volvo by obd. Sid 803 or sid803a in Volvo 2.0d 136ps
FILE SERVICE
Volvo with EDC16C34 has no kline connection, that's why it could not be readed via OBD
Autotuner user
Kess/Ktag
WinOLS
SID206 is model of ecu in this model mate ,just bdm is the best thing
Proffesional ECU & TCU Tuning
Petrol and Diesel Engines
File Service
nope, sid 206 is only with MPS6 gearbox
ha ha ha, thats right sid206 only mps6 gear. This ecu to any problem read kess by obd. Edc16c34 read terminal or smok up 2006y in xc90 by obd......
FILE SERVICE
Hello voltechcar ,
Can you confirm SID206 can be read/written with KESS?
If Yesn can you please give Kess version soft?
Sorrt I'l still green...
Many thanks,
I forgot to specify car is a Volvo s40 2008 136hp Diesel
i have genuine kess, now is version 3.03
FILE SERVICE
I read yesterday volvo v50 1.6d i put in pin 9 obd cable to ecu cable pin 47 (kline) and after these procedure i can read/write over obd.
Verstuurd vanaf mijn SM-A520F met Tapatalk
Sedat Garip
Belgium
With Kind Regards,
bugarcek (2nd February, 2019)
