Touareg 3.0 TDI DPF regeneration
Results 1 to 9 of 9
    Feb 2017
    Default Touareg 3.0 TDI DPF regeneration
    Hi. I need help with a Touareg 3.0 TDI, BKS engine.
    I can not do the forced regeneration of the DPF particle filter.
    Temperature with goes from 200 degrees Celsius.
    The differential pressure sensor has been changed and the temperature sensor before the dpf filter.
    The MVB 102.1 is always at 899 degrees centigrade.
    Help, help
    Jun 2009
    Look at MWB 101/3, you don`t reached the temperature for regeneration.
    102/1 is temperature after pre-catalyst until 11.2005
    102/1 is temperature prior pre-catalyst after 11.2005 and then it is a calculated value
    Look here for instructions http://wiki.ross-tech.com/wiki/index...y_Regeneration
    Feb 2017
    So, how can I see if the turbo temperature sensor (102/1 is temperature prior to pre-catalyst after 11.2005 and then it is a calculated value) is OK?
    The reference is 059906088A.
    Someone has the ELSA Win to see the values in ohms?.
    Jun 2009
    In elsa there are no data for Ohm, you must see in odis
    What build year is your car ?
    Feb 2017
    3.0 TDI BKS 2007
    The sensor has 205 ohms with the engine cold. I think it's okay.
    The problem is that I can not raise the DPF temperature, it will not be the EGR valve?
    Pyromaniak's Avatar
    Aug 2015
    ~~~~ing CZECH
    i think dpf its off in ecu, if the temperature are same for all time
    My English is little bit bad, but day after day is better. Like my experiences https://www.youtube.com/channel/UCdT...bx2Pc7WI4pWUWA
    My help not for free, press THANKS and REP, for make me HAPPY
    im not using passwords, my work is for this forum and members free
    Feb 2017
    How does the EGR work when it is in regenraracion?
    Open or closed the EGR cooler?
    Open or closed the EGR?
    Jun 2009
    EGR is closed in regeneration
    Picture is from 4 cyl
    epicsabi's Avatar
    Budapest
    I have same problem with Tuareg 3.0 TDI BKS engine.
    The MVB 102.1 is 899 C degrees
    What was the solution for this problem?
