Immo AVEO :generate transponder problem. Help please !!
    sergei5005's Avatar
    Nov 2012
    Bs As
    Default Immo AVEO :generate transponder problem. Help please !!
    Hi friends. Im try programm one transponder for chevrolet aveo without sucess. Now the car is repair in other workshop. Only for experience need help. As i do make one transponder ?? Im can read antena with 93C56 eprom. Read OK INMO AVEO.jpg Im can`t extract pin code or generate transponder with mini zed bull . Im have Mini zed bull clone,and SBB clone. Any help ??? THANKSSSSSSSSSSS !!!!
    Top Poster ISIV's Avatar
    Feb 2013
    Somewhere in the univers
    I think you have to invest some money into more expensive and serious tools
    rob h's Avatar
    May 2011
    post dump here
  4. The Following User Says Thank You to rob h For This Useful Post:
    sergei5005 (20th January, 2018)
    Aug 2015
    use sbb, works good
  6. The Following User Says Thank You to dtip For This Useful Post:
    sergei5005's Avatar
    Nov 2012
    Bs As
    Thank you. Very good you help.....
  8. #6
    Hello friend, if you do not let you code the transponder, record this file in memory, and use the sbb to encode one or two tp08 transponders.
  9. The Following User Says Thank You to ALBERTO_ For This Useful Post:
