Results 1 to 11 of 11
    Member carber78's Avatar
    Sep 2011
    San Antonio, Texas. USA
    Default 2010 Mini Cooper R56 Dme Change Used Cloned.
    Hello I have a 2010 mini cooper R56 that I need to change the Dme I tried reading the old one with ktag and DimSportand cloning it but the isn Number needs to be changed in cas module. I have read the cas module withx prog MC9S12XDP12CAL and have the dump from it, also have the dump from the dme. but I tried loading it to isn tool and the cas .bin will load but the dme dump doesn't load it continues to say error. I tried reading it with Galletto and I have the same problem it is a bosch 17.2.2 tricore I read it with boot mode.
    can anyone help me tha might have bmw explorer or autohex II to modify the cas dump with the new isn from replacement dme. I wold really appreciate it.
    Dec 2017
    Poland-Germany-Ukraine
    what type of processor, 1767 ?
  3. The Following User Says Thank You to Sidemark For This Useful Post:
    carber78 (23rd January, 2018)
    Sep 2011
    Quote Originally Posted by Sidemark View Post
    Sent from my iPhone using Tapatalk Pro
    Sep 2011
    Quote Originally Posted by carber78 View Post
    Dec 2017
    U have to read 32kb internal processor eeprom !!!
    And tell u one more thing - u have to read old one dme eeprom to get isn from it, because your eeprom in cas is crypto !
  7. The Following User Says Thank You to Sidemark For This Useful Post:
  8. #6
    Sep 2011
    Default here is the read off of the original dme
    here is the dump off of the original dme.
  9. #7
    Dec 2017
    There is no eeprom 32kb in it. Try with ktag (no galleto and ktm)
  10. The Following User Says Thank You to Sidemark For This Useful Post:
  11. #8
    Sep 2011
    Ok thank you! Let me try with ktag
  12. #9
    Sep 2011
    ok here is the read of the new dme I still need to read the old dme with ktag
  13. #10
    Dec 2017
    It is the same like before. I dont see isn in your files. U can try read like full backup - may be that way we will do something.
  14. The Following User Says Thank You to Sidemark For This Useful Post:
  15. #11
    Hello Friend...
    Please, save the Edm file (with ktag or Ktm100), if you have not modified the Cas, it does not matter, just modify the Ecu.
    The files: https://mega.nz/#!VmwmQZiJ!Yp_NFlVOt...5Jr8VzahopMdc8
    Post results
  16. The Following 2 Users Say Thank You to ALBERTO_ For This Useful Post:
    carber78 (23rd January, 2018), utek (25th January, 2018)
