Hi everyone,
I have a problem with my car, i tried to turn on the car, it keeps on in 5 seconds and after that it turns off.
MB275800 - 9542
GM - 55571776
NF - D09005
I tried repair the eprom, 93a86_ic502 and 93a86_ic503, but I was unsuccessfull.
Does anyone can confirm if theses files are ok?
Report:
--- read diagnostic trouble codes ---
P2688:
Symptom Description: no additional information
Status: Present
P0380: Glow Plug/Heater Circuit A Malfunction
Symptom Description: Short to Battery
Status: Present
P0645: A/C Relay Circuit Malfunction
Symptom Description: Low Voltage/Open
Status: Present
P0615: Starter Relay Circuit Malfunction
Status: Present
P0243: Turbocharger Wastegate Solenoid A Malfunction
Status: Present
P0660: Swirl Level Control Solenoid Valve
Status: Present
P0638: Throttle Actuator Control Range/Performance
Status: Present
P0480: Fan Control 1 Circuit Malfunction
Status: Present
P0481: Fan Control 2 Circuit Malfunction
Status: Present
P0482: Fan Control 3 Circuit Malfunction
Status: Present
P2425: Exhaust Gas Recirculation Cooler Bypass Solenoid Valve Circuit
Status: Present
Thank you for your help.
Ziex
